Replacing tired H22 with slightly used H23...Questions
Old Aug 13, 2006 | 05:13 PM
Rwecked's Avatar
Default Replacing tired H22 with slightly used H23...Questions
I figure if I'm swapping out engines, I may as well go VTEC so what I want to know is, is there anything else from the SRV (2.2) that I may also need? Thanks guys, I normally drive my EP3 or DC2R so I really don't have alot of experience with my wife's Prelude.
Old Aug 13, 2006 | 07:08 PM
phateless's Avatar
wait, you're putting the vtec motor in or taking it out?
Old Aug 13, 2006 | 07:12 PM
blackdelslo's Avatar
Default Re: (phateless)
According to your title your taking out the vtec motor and putting in a non vtec
Old Aug 13, 2006 | 07:14 PM
phateless's Avatar
we just want to clarify so you get the correct information
Old Aug 13, 2006 | 07:15 PM
RJonathan's Avatar
Default Re: Replacing tired H22 with slightly used H23...Questions (Rwecked)
if you're swapping out the Vtec and putting in the non vtec and of course i'm assuming both motor is OBD1 because H23 was only made for OBD1 then you dont have to swap anything from the Vtec motor over to the non vtec motor.
but if you're swapping out the H23 for a H22 then all you have to do is wire for Vtec.
The title said you're swapping out a H22 for a H23 but then in your post you said you're swapping out a H23 for a H22
Old Aug 13, 2006 | 07:24 PM
phateless's Avatar
96 ludes were obdII.
cccya
Feb 5, 2007 10:21 AM
xxredpreludesixx
May 3, 2005 05:49 AM
two fast 4 you
Dec 28, 2003 08:23 PM
orock99
Mar 9, 2003 06:27 AM
