car wont start....help
Old Aug 13, 2006 | 04:58 PM
the.hamburglar's Avatar
Default car wont start....help
ok ill briefly explain this. put the key in it primed for a few secs and then went off so then i turned it over and it souned as though the battery was dead becuase it was turning over so slow. so i never tested it, it just seem obvious that itw as the battery. so i swapped battiers out of my other car (thats all i did was swap batteries and now i turn the key and it doesnt even prime. the SRS light goes off after about 10 seconds but my check engine light stays on. i turn the key and nothing happens, it kinda sounds like when you dont have the clutch in and start the car. WHERE CAN I START?
checked power to starter.
tried new starter.
checked all fuses.
checked engine codes but there is nothing. the engine light just stays on it never blinks.
Old Aug 13, 2006 | 05:00 PM
Miracle's Avatar
Default Re: car wont start....help (the.hamburglar)
Bad ground or a bad cable. Did you clean up the terminals and the cable ends on that battery for a solid connection?
If nothing like that works, I suggest testing the resistance in the cables. The dealer or a website should have specs for resistance in the cables. Ill see if I cant come up with something......
Old Aug 13, 2006 | 05:37 PM
Default Re: car wont start....help (Red_EM2)
yeah but my lights and radio work fine so if it were a bad connection then wouldnt these not work?
Old Aug 13, 2006 | 07:26 PM
B18bEG6ick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">yeah but my lights and radio work fine so if it were a bad connection then wouldnt these not work?</TD></TR></TABLE>
yea that is true, but if you have a high resistance on the battery cable it would still work. try to check the resistance to the cables and maybe do a cable to post voltage/resistance?
Old Aug 13, 2006 | 07:28 PM
Sleepy_Red_hatch's Avatar
Default Re: car wont start....help (B18bEG6ick)
not necessarily, the starter is a battery *****.
Old Aug 13, 2006 | 09:32 PM
Default Re: car wont start....help (Sleepy_Red_hatch)
its all good guys, i totally forgot about the tranny ground. i had a long wrech resting between the tranny and chassis. i guess that was a good enough ground to make the starter turn slowly. anyways i used that same wrech to take off the battery and then i put the wrench back in the toolbox. therefore i had no ground at all when i put the new battey in because the wrech was gone and the ground cable i forgot about. ahahahah. who would have thought
beat
Aug 8, 2009 12:46 AM
JDM EJ2
Jul 6, 2008 04:39 PM
silverdragon277
Aug 19, 2006 10:42 AM
MikeM324
Dec 20, 2005 05:36 AM
90LSpimpin
Oct 6, 2004 10:06 PM
