1989 crx brake conversion please help??????
Old Aug 13, 2006 | 04:28 PM
bman2033's Avatar
Default 1989 crx brake conversion please help??????
ok so i need a little bit of help on a list of things that i need to do a whole rear brake conversion and if i could do the fronts too i would like too, but i dont know what to get, like which integra to do the swap off of and i also heard that i would need a new master cylinder and i think a new proportioning valve or something like that, can some one help me out with a whole list and then i could start my purchasing please help, ohh one more thing i dont want to get a big brake kit cause it only change the front and its well over a 1000 dollars, lol. help thanks alot in advance
Old Aug 14, 2006 | 05:44 AM
bman2033's Avatar
Default Re: 1989 crx brake conversion please help?????? (bman2033)
bump
Old Aug 14, 2006 | 07:03 AM
EL Vap133's Avatar
You need either 90-93 Inetgra front brakes, or 90-91 Civic EX brakes for the front.
For the rear you need 90-91 CRX Si brakes, or 90-93 Integra brakes.
Old Aug 14, 2006 | 10:59 AM
HiProfile's Avatar
Default Re: 1989 crx brake conversion please help?????? (EL Vap133)
You could also go with any 92+ civic rear discs, and 94+ teg rear discs. I wouldn't suggest the 90-93 front brakes, since you need to use the teg spindle, which messes up your suspension geometry. I'm assuming its not an Si, so you could get front calipers from a 94+ accord wagon/newer Odyssey/ITR, and they bolt right on with 92+ civic rotors and ~3mm shaved off the mounting surface for the caliper brackets (bracket-to-spindle surface). Note that you'll need at least 14" rims, maybe 15". That with a master cyl/brake booster upgrade, and your will have killer brakes.
Old Aug 14, 2006 | 05:58 PM
bman2033's Avatar
Default Re: 1989 crx brake conversion please help?????? (HiProfile)
i have a 1989 crx SI so I dont know if that really helps because ^^^^^ mentioned that he thought i didn't so civic si fronts and integra rears adn what about the master cylinder or the valve???
Old Aug 20, 2006 | 07:50 PM
bman2033's Avatar
bump
Old Aug 20, 2006 | 07:57 PM
IndySporty's Avatar
get the booster, master cylinder, and proportioning valve off a 90-93 teg non ABS
Old Aug 20, 2006 | 08:06 PM
gsxr1k05's Avatar
you can use the 94 integra rear assembly as well. its what i got. and you DONT HAVE to change the master cyclinder, booster and prop valve, the pedal will just go to the floor more than normal if you dont.
u can also use the booster/ mc/and prop valve from a 94 teg as well. or any other year. mine were all 94 teg and i used the 1 inch m/c. however, if u change to the 1 inch m/c you will need the hard line that goes from the back of the m/c to the prop valve from same year integ. the stock crx one is too small on the flared fitting. you also need the caliper lines for the rear from the teg. they bolt right up to the hard line.
the ebrake cables from the si will work but you need the 91 si cables i believe.
also, that teg line from the prop valve to the m/c is a little long, i have mine running under the m/c and over the top of the resivor then to the m/c.
i will have pics when i get back home from cali on the 15th,
Old Aug 20, 2006 | 08:42 PM
bman2033's Avatar
Default Re: 1989 crx brake conversion please help?????? (gsxr1k05)
cool cool i def needs some pics and if u could show me some of the brakes themselves too that would be cool but if i know what im talkin about but dont know how to do it myself should i get professional help, cause i had my swap done professionally should i just go back to the to do the swap on the brakes and the m/c and valve, ect. ???? i would do the brakes myself i just dont have the right tools
Agguhnitus
Suspension & Brakes
Feb 15, 2012 03:07 PM
Agguhnitus
10
Feb 14, 2012 02:04 PM
crxturbo585
Jan 12, 2008 07:35 PM
redwards
Mar 26, 2007 01:22 PM
TyConway21
Sep 10, 2006 02:41 AM
