ZC Swap Exhaust Question
Old Aug 13, 2006 | 03:05 PM
neonphire8604's Avatar
Default ZC Swap Exhaust Question
I just swapped a dohc ZC into my 91 Si hatch, and I used the stock zc header\downpipe, but the gasket that goes in between the two was missing, which is causing an obvious exhaust leak. Where can I get one of these, or something to make my own? Thanks in advance
Old Aug 14, 2006 | 10:43 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: ZC Swap Exhaust Question (neonphire8604)
Get a gasket for a 88-91 Civic/CRX for the same location. Costs like $15 from a dealership.
Old Aug 14, 2006 | 12:04 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: ZC Swap Exhaust Question (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Get a gasket for a 88-91 Civic/CRX for the same location. Costs like $15 from a dealership.</TD></TR></TABLE>
sounds like he is saying the gasket between the upper manifold and lower manifold (correct me if i'm wrong). if it is that particular part, the one for a SOHC won't work since it's 4-1 unlike the DOHC ZC manifold which is 4-2-1.
i don't remember there being a gasket for mine. but the 92-95 SOHC VTEC manifold is similar in design to the DOHC ZC. if there is a gasket for that particular area, try getting on from that year motor.
then again i could be wrong
Old Aug 14, 2006 | 12:17 PM
jlicrx's Avatar
Default Re: ZC Swap Exhaust Question (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">
then again i could be wrong </TD></TR></TABLE>
you are correct - 92-95 Civic EX is what is needed - it uses 2 round gaskets
OEM part no. 18212-SB2-961
or from Checker
http://www.partsamerica.com/Pr...asket
BigbamaBen
Dec 21, 2011 07:28 AM
R.coustom
May 22, 2009 09:34 AM
Wheelman-CZ
Nov 15, 2006 04:41 AM
civicflow
Oct 1, 2004 04:37 PM
sabertooth
May 28, 2004 05:36 PM
