Very Hard Shifting(H22a)
Old Aug 13, 2006 | 02:36 PM
crxhybrid85's Avatar
Default Very Hard Shifting(H22a)
I'm having a hell of a time in my car. It's an OBD1 H22a with non lsd tranny. The problem is with the shift lever. It goes forward and backward with no problem, but left to right going from 2nd to 3rd, 4th to 5th, and same thing back down. I have to hit my shifter with the ball of my fist to get it into the middle and then it goes up into 3rd no prob, and then down into 4th is fine etc.
I disconected the right cable from the shifter and it is still hard to move left and right so I believe it is something in the shift box itself. I looks like there is a rectangular piece that the shift lever sits on and is supposed to rotate. Anyone have any experience with this getting jammed up somehow?
Any other ideas?
Old Aug 13, 2006 | 02:42 PM
BDRphaSe2's Avatar
hmm take ur shift box out and ur shifter, and apply more/new grease? all i can think of
Old Aug 13, 2006 | 02:46 PM
lsvtek's Avatar
Default Re: (BDRphaSe2)
its your master cyinder or your slave, they are worn
Old Aug 13, 2006 | 02:49 PM
Default Re: (4drlsintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drlsintegra &raquo;</TD></TR><TR><TD CLASS="quote">its your master cyinder or your slave, they are worn</TD></TR></TABLE>
Could you elaborate a little more? It feels like its just stuck, not sure how the slave or master cylinder would affect that? The clutch engages and disengages perfectly. It's just moving the lever left and right that is hard.
Old Aug 13, 2006 | 05:55 PM
JasonST's Avatar
Dude maybe I'm wrong, but what the heck would the master or slaver cylinder have to do with the shifter moving from left to right, the cylinders would only affect the clutch. The only thing I can think of since u already dissconnected the cable and still have the problem is what BDRphase2 said, try greasing ur shifter and that should help.
Old Aug 13, 2006 | 06:21 PM
Default Re: (JasonST)
I got underneath the car and basically the lever sits on a pivot ball that is bolted to the shift box. It does looks like it could be greased so I'm going to go to autozone tomorrow and get some heavy duty grease and see if I can get it in there.
Old Aug 13, 2006 | 06:35 PM
yOnKiNaToR's Avatar
Default Re: (crxhybrid85)
i had the EXACT problem when i boughta m2a4 tranny off a guy.. apparently in shipping the shift linkage housing was slightly damaged. it bent the shift arm on top of it (which is for left and right movement) and caused the movement to be like the tranny had 90 wt fluid in there.
i replaced the housing with the one from my old h23 tranny and it's like butter. in case you don't know what the shift linkage housing is, here's a pic:
my # 5 was very slightly bent and something was messed up with the tension (i think) on spring #7 and #8.
just something to consider.
Old Aug 13, 2006 | 06:41 PM
Default Re: (yOnKiNaToR)
Thanks, I'll have to check that out tomorrow. Looks like I can see it from the top if I remove the intake?
Old Aug 14, 2006 | 01:02 PM
yOnKiNaToR's Avatar
yes you can see if if you remove the intake.
btw, the only way i knew mine was bent was that the shift arm was bent inwards and didn't allow me to fit a 10 mm deep socket into the bolt closest to the arm and on my h23 it did. very hard to tell but made my 3rd, 4th, and 5th gear at least 1/2-1 inch over to the right when shifting.
Old Aug 14, 2006 | 01:39 PM
Kagelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">i had the EXACT problem when i boughta m2a4 tranny off a guy.. apparently in shipping the shift linkage housing was slightly damaged. it bent the shift arm on top of it (which is for left and right movement) and caused the movement to be like the tranny had 90 wt fluid in there.
just something to consider.</TD></TR></TABLE>
i secound that
Mine just snapped i have no idea how but i look and pieces were falling off of it. replaced it with the bracket and it was all good
Modified by Kagelude at 3:31 PM 8/14/2006
Old Aug 17, 2006 | 08:30 AM
Default Re: (Kagelude)
My little bracket there doesn't seem to be bent, I was looking at it today. I was under the car though and feeling along my shift cables and right where they go over the cross member I can feel a break in the rubber on both of them. Unfortunately I can't get at an angle to see them. It feels like one of them is plastic under the rubber and one is metal/cable exposed. Could that be the problem?
Old Aug 17, 2006 | 10:04 AM
ninja 6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">
Dude maybe I'm wrong, but what the heck would the master or slaver cylinder have to do with the shifter moving from left to right, the cylinders would only affect the clutch. The only thing I can think of since u already dissconnected the cable and still have the problem is what BDRphase2 said, try greasing ur shifter and that should help.</TD></TR></TABLE>
you're right, the master and slave clutch cylinders have nothing to do with having the shifter going left to right. theres something wrong with the shifter assembly on top of the transmission housing, or somethings messed up inside your gearbox
Old Aug 17, 2006 | 02:55 PM
All-Motor-Junkie's Avatar
^^ +1
SHG_Claudio
25
Nov 2, 2010 12:45 PM
'95 BA8
Jun 18, 2010 06:46 AM
ptj20
Nov 8, 2007 09:31 AM
Trian
Jun 19, 2006 02:33 PM
Da1Gsr
Feb 26, 2006 05:53 PM
