ITR Wheel specs
Thanks for the info. I was wondering why I never hear of wheel swapping ITR <--> Subaru (+53mm offset, 16x7, 100mm bolt circle).
Ah well. Anyone know the specs for the wheels on the Lexus RX300 or IS300?
if you are looking for a cheap alternative wheel to mount race tires on, then you might want to look into the 1995 ish Mazda Milennia Wheels. Exact same specs as the ITR, but they weigh ~ 12lbs... you can usually find all 4 four around 200 dollars
try
http://www.car-parts.com
or see if anyone on the boards has a set for sale
try
(Center caps : 35 dollars extra!
