BENEN real lower tie bar
anyone know what size bolts i will need? standard or metric? and thread pitch?
i bought it used no bolts just the bar
BAY AREAAAAAAA!!!!!!!!
EDIT:...not real...puhahaha...i mean REAR!!!
I've seen it and if it looks like what I saw then you need extended bolts. Go to napa and get them for like $1, make sure they have the same thread pitch otherwise they won't fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninety-five_DB »</TD></TR><TR><TD CLASS="quote">bolt is metric right???</TD></TR></TABLE>
yes.
if youwant exact measurments, go a honda parts website and get the pitchthread and size there.
yes.
Make sure you get Grade 10.9 metric bolts. Metric Grade 8.8 bolts the same strength as SAE Grade 5 so you don't want them holding suspension together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">Make sure you get Grade 10.9 metric bolts. Metric Grade 8.8 bolts the same strength as SAE Grade 5 so you don't want them holding suspension together. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">take off your bolt, and go to a hardware store they should have it, homedepot. or whatever. get a longer one. </TD></TR></TABLE>
ACE Hardware
ACE Hardware
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">wheres the suspension tech?
(chassis stiffening is not suspension)</TD></TR></TABLE>
are you f'in serious? what is the matter with you? did you get all your panties, better yet, thongs in a bunch because i posted a "chassis stiffening" question in the suspension thread? WHO GIVES A F*CK? well, obviously you since you wasted your time to post an uninformative reply. what a square bear!
...and the sad part about it, is that you thought posting your comment would make me look stupid...so tell me why everyone else who replied gave me informative info while you sat there tryin to be a smart ***?
"GO F*CK A GOAT!"
"GO F*CK A GOAT!"
