I need wiring HELP
Old Aug 13, 2006 | 10:43 AM
silentdaredevil2's Avatar
Default I need wiring HELP
I have this plug left over after putting my dash back in and i can't seem to find its home. Heres my problem. i turn the key on but i don't start the car, and nothing happens. Usually the check engine light comes on and you can hear the fuel pump presserize the system. Nothing happens. Also when theres no key in the ignition the SRS light is on and my e brake light is on (The ebrake is on though) Im lost on what to do. Im hoping this plug will solve my problem.
Old Aug 13, 2006 | 11:11 AM
B18EG6's Avatar
Default Re: I need wiring HELP (silentdaredevil2)
I can try to help you, I have a few harnesses here from a few cars... what type of harness is it? What are the details, is this for your 92-95 civic? Is the harness for OBD 1?
Old Aug 13, 2006 | 11:30 AM
jime64871's Avatar
Default Re: I need wiring HELP (B18EG6)
i'm asuming it hangs from your driver side, if so, i believe it connect to the back of your fuse box. Top right hand (towards middle) of the fuse box. Take down your fuse box and check it out. There's like 4 or so plugs that connect to the back and i think that is one of them.
Old Aug 13, 2006 | 12:33 PM
B18EG6's Avatar
Default Re: I need wiring HELP (jime64871)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jime64871 &raquo;</TD></TR><TR><TD CLASS="quote">i'm asuming it hangs from your driver side, if so, i believe it connect to the back of your fuse box. Top right hand (towards middle) of the fuse box. Take down your fuse box and check it out. There's like 4 or so plugs that connect to the back and i think that is one of them.</TD></TR></TABLE>
hmm.. sorry, I dont think thats it All of the green connectors that plug into the back of the fusebox are all dual contact ones, while the picture illustrates a single row of contacts. I can get a picture if ya want )
At first I thought the plug was for the maintenence box, but that one has less wires (and different colors!)
The dead pedal means the car is not a DX model, I know they came in LS teg's but not sure about different Civics
Is the problem a result of dash swap?
Old Aug 13, 2006 | 01:05 PM
it is a 94 civic ex and i had the dash out because im doing a shave/tuck on my bay. any pictures, or anything will help i need to figiure this out
Old Aug 13, 2006 | 01:18 PM
that plug is not to the fuse box its to the power mirror switch so now im really at a loss. what woudl cause the cluster and fuel pump to not work?
Old Aug 13, 2006 | 02:22 PM
also i noticed when i hook up the battery cables the wire that runs to the starter and all the ground cables get real hot. what does this mean?
Old Aug 13, 2006 | 02:23 PM
B18EG6's Avatar
Default Re: (silentdaredevil2)
Edit - OOps... I got halfway out to the car when I noticed you said you found what plug it was and dammit, you beat me to my post!
Sounds like a ground problem (hehe, when isnt it a ground problem )
Dumb advice, but go along your harness and check for loose grounds / connectors. Check the connections at the main relay. Use a multimeter and check for (+)Batt voltage where it is supposed to be, and use the continuity check to find check the grounds at the connectors.
I dont have an EX but I can go check my harness for that connector. Lemme make sure I ID'd it correctly... looks like ~7 wires
blk
blk/yel
blu/wht
yel/red
yel
blu
yel/blk
I will go see if I can find it!!
Old Aug 13, 2006 | 03:37 PM
NJcoupe's Avatar
Default Re: (B18EG6)
Its for the power mirror switch.
Old Aug 13, 2006 | 04:35 PM
the switch is out of the question i need to know whats up with these wires getting hot
Old Aug 14, 2006 | 11:46 AM
B18EG6's Avatar
I PMed you, could you have switched the batt (+) ans alternator input to the underhood fusebox?
Old Aug 14, 2006 | 12:40 PM
no i figured it out. the terminal for the starter wire was touching the starter case and grounding out. Fixed that up and it works perfect
Old Aug 18, 2006 | 06:14 PM
B18EG6's Avatar
awesome!!! I will keep that in mind when I put my stuff back together
1990whitecrx
14
Sep 27, 2010 09:34 AM
Xplicitz
Nov 1, 2009 09:04 AM
bluez6
Aug 27, 2008 08:03 PM
Revolemilbus
Jan 13, 2007 12:32 PM
neiloneil03
Sep 14, 2002 04:28 PM
