F23A4 in a CRX?
Old Aug 13, 2006 | 08:16 AM
WorrGame13's Avatar
Default F23A4 in a CRX?
One of my friends with an accord is selling his F23A4 motor. I was thinking about getting it for in my 91 CRX Si. But I wanted to see if anyone one knew if it's been done before or the difficulty of the task? It's a 2.3L USDM SOHC ULEV VTEC from a 98 Accord with 148hp.
Any advice or input otherwise would be helpful. Thanks for looking.
Old Aug 13, 2006 | 10:37 AM
Pooby88's Avatar
Default Re: F23A4 in a CRX? (WorrGame13)
F-motors have been put in CRXs, but you don't see it too often. Difficulty-wise, it is about the same as an H22 install. I wouldn't consider it unless you're getting the motor very cheap, or you just want to have a motor that almost nobody has in a CRX.
Old Aug 13, 2006 | 10:44 AM
ExplicitSpeed360's Avatar
Banned.
Our EF H22A motor mount kit may work for 2 of the 3 mounts you may need to modify the transmission mount. Same idetical process as and H22.
http://www.ExplicitSpeedPerformance.net
Old Aug 13, 2006 | 01:13 PM
doublethink's Avatar
well its cute that you post the crank horsepower of the enigne, but most b16a's make more then that.
the advantage of that motor is the torque, and it has pleanty.
good luck with one wheel peeling and torque steer.
all of first and second will be spent moving diagonally to the right.
(im very much joking!!!!)
some of the fastest civics are worked accord motors swapped. the disadvantage of it is theres never really been a bolt in way to do it.
20crx
Feb 20, 2007 03:53 AM
stock00civic
Dec 10, 2005 01:58 PM
gorillaz
Jul 31, 2005 09:32 PM
540i6
Jan 8, 2005 06:40 PM
