is it safe to run with no front mount on swap?
Old Aug 13, 2006 | 07:26 AM
97grnrs's Avatar
Default is it safe to run with no front mount on swap?
i had my setup for a while n my 91 hatch. ls turbo. it has alot of torque. i had a makeshift front motor mount setup to help a lil but i broke it at the track. now im left with the 2 sides and the rear mount only.. i def notice the motor moves a lil more without the front mount i had but is it safe to only use 3? i just dont wanna end up ripping the motor out of the car on a real hard launch..
Old Aug 13, 2006 | 07:29 AM
zccr-xsi's Avatar
imo i would considering thats your tq. mount.that keeps the engine from moving.
hatchinprogress's Avatar
Default Re: is it safe to run with no front mount on swap? (97grnrs)
i've never ran with just those 3 mounts (but i plan to for a lil bit, due to the aftermarket crossmember) i would think you could drive w/3 mounts but i wouldnt race or anything...the motor will probly shift pretty good, and you will loose traction and get wheel hop
Old Aug 13, 2006 | 07:36 AM
user 98292739's Avatar
hmmm what kind of mounts are you using? hasport?
i just bought the innovative crossmember with the front solid tq mount
Old Aug 13, 2006 | 07:54 AM
TurboRy's Avatar
with some strong, stiff mounts you really dont need that mount on the trans.
Old Aug 13, 2006 | 08:05 AM
USDMSiR's Avatar
Default Re: (TurboRy)
yeah i have really stiff hasport mounts and it didnt come with a tq mount. they said it wasnt needed. it just depends on how stiff your mounts are.
Old Aug 13, 2006 | 08:29 AM
ludesrv's Avatar
You can run it, over time and abuse, the rear motor mount with rip the rear sub frame, no word of a lie. You will have to weld/replace it.
Get a supportive cross member for the engine if you want to make your life easy.
Old Aug 13, 2006 | 08:59 AM
97grnrs's Avatar
Default Re: (ludesrv)
i did rip the rear crossmember once. thats why i worry now
Old Aug 13, 2006 | 10:00 AM
Max Kling's Avatar
I ran with out the front one, and broke the back one and had to drive 20 miles with just the 2 side mounts which was horrible. Its only a matter of time before that back one goes.
And the person who said you can run without the rear tranny mount dosent know wtf hes talking about.
Old Aug 13, 2006 | 02:21 PM
TurboRy's Avatar
Default Re: (Max Kling)
Uhmm..if you read the OP he's talkin about runnin w/out the front trans mount. Which should be fine as long as he's running some stouter mounts.
Reading>u
silverbullet9626
10
Apr 2, 2011 06:45 PM
es_squared
Jan 27, 2009 07:22 PM
bballchris24
Sep 7, 2007 11:09 AM
91crxturbo
Jan 10, 2007 08:03 PM
Kwuaymaikrup
Apr 27, 2003 02:37 PM
