header question
Old Aug 13, 2006 | 06:14 AM
USDMSiR's Avatar
Default header question
I have a 90 crx with a b16 and im putting in a header. the whole front of the car is off, radiator, fan, bumper and crossmember support thing. but the damn header wont fit past the cross member. any suggestions on what to do. i need this car runnign TODAY!! i have to work on monday
Old Aug 13, 2006 | 06:26 AM
zccr-xsi's Avatar
take it off and nocth it out the put it back on.
Old Aug 13, 2006 | 06:31 AM
jhota's Avatar
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">take it off and nocth it out the put it back on.</TD></TR></TABLE>
i hope you mean the cross member, not the header!
USDMSiR's Avatar
notch the crossmember?
Old Aug 13, 2006 | 06:35 AM
USDMSiR's Avatar
Default Re: (USDMSiR)
what should i use to "notch" it? i tried bending it down but its a pain in the ***.
Old Aug 13, 2006 | 06:39 AM
zccr-xsi's Avatar
use a cut-off wheel
Old Aug 13, 2006 | 06:40 AM
zccr-xsi's Avatar
also try beating the **** out of it.see if u cnat dent it in far enough to give the header room to fit.wont look as good as notching it but will get the job done.
Old Aug 13, 2006 | 06:41 AM
zccr-xsi's Avatar
Default Re: (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">
i hope you mean the cross member, not the header!</TD></TR></TABLE>
yes i meant the front lower crossmember NOT THE HEADER!thats stupid question
Old Aug 13, 2006 | 06:42 AM
USDMSiR's Avatar
yeah, thats what im thinking. would you recommend taking the crossmember out? cause if i have to do that i think it will fit without denting. idk.
Old Aug 13, 2006 | 06:43 AM
zccr-xsi's Avatar
oh hell yea! doing it in the car will be a pian in the ***.take it off much easier to get to.
Old Aug 13, 2006 | 06:46 AM
zccr-xsi's Avatar
i think they are 4 17mm bolts,two bolts for each side.and i need to take out them radius arms too.
Old Aug 13, 2006 | 07:08 AM
jhota's Avatar
yes i meant the front lower crossmember NOT THE HEADER!thats stupid question </TD></TR></TABLE>
hey, i've never done a B-series swap, but i would have known to notch the crossmember. i've seen people do some dumb things, and i wanted to be sure that he didn't follow the formal syntax of your statement - which would have instructed him to notch the header.
if you've got access to a welder, it'd probably best to cut out a clearance area then box it back in. otherwise, you are stuck with the "cut and bash" method.
make a couple vertical cuts on either side of the area where the header rubs, deep enough that the header would clear, then beat the area between the cuts with a BFH until it goes concave. re-install.
Old Aug 13, 2006 | 07:20 AM
zccr-xsi's Avatar
Default Re: (jhota)
make a couple vertical cuts on either side of the area where the header rubs, deep enough that the header would clear, then beat the area between the cuts with a BFH until it goes concave. re-install.</TD></TR></TABLE>
now thats a good ideal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">i've seen people do some dumb things,</TD></TR></TABLE>
yea so have i.i seen things done that would just make u laugh.
Old Aug 13, 2006 | 07:35 AM
USDMSiR's Avatar
cool, so i got the crossmember out (piece of cake) and installed the header expecting everything to line up. well it didnt. oh well, im taking a breakfast break and going at it again. the metal seems to be forgiving so im taking a hammer to it and spraying it black after words. no one will know.lol
Old Aug 13, 2006 | 09:37 AM
USDMSiR's Avatar
ok, got the header in, crossmember finished. i took it for a test drive and i can hear this annoying clicking sound. its almost like a midget shaking a bottle with a nut in it. its weird. only when im on the throttle.
BTW, i can tell a difference in acceleration and its hella loud. lol
Old Aug 13, 2006 | 04:52 PM
zccr-xsi's Avatar
clicking souynd? can u hear it when your ideling and have the hood up?
Old Aug 13, 2006 | 09:23 PM
janz3n's Avatar
exhaust leak maybe? did you use a new gasket for the headers?
Old Aug 14, 2006 | 05:28 AM
USDMSiR's Avatar
Default Re: (janz3n)
yeah, i think it was a leak. two nuts fell off. mabey i didnt tighten them up. so i slapped two new ones and it went away. thanks.
ericstambaugh07
May 27, 2007 06:15 PM
Kevedge
Welding / Fabrication
11
Jun 26, 2005 08:41 PM
slow91crx
Jun 3, 2005 04:54 AM
S@nt0s
Apr 25, 2004 05:28 AM
