replace just brake pads or rotors and pads
Old Aug 13, 2006 | 06:01 AM
sony224422's Avatar
Default replace just brake pads or rotors and pads
is there any reason i should replace the rotors.. or can i just replace the pads? I know if the rotors are warped or low that you can't reuse them, but if they are ok is it safe to re use them?
Old Aug 13, 2006 | 06:56 AM
Duane_in_Japan's Avatar
Default Re: replace just brake pads or rotors and pads (sony224422)
Are they trapped rotors or will they just pop off, any place that can turn them can inspect them, meaning they can check for runout, warpage and thickness, if those three pass then the first rule of turning rotors is only turn rotors that need turned, dont mess with a good thing and ignore Murphys Law.
Old Aug 13, 2006 | 01:59 PM
sony224422's Avatar
Default Re: replace just brake pads or rotors and pads (Duane_in_Japan)
they are "trapped" i guess.. whatever the hard ones to get off are. I don't think i would need new rotors, but im pretty sure i need new pads. I'm actually going to check the wear of them right now
Old Aug 13, 2006 | 02:10 PM
BLKFLSH's Avatar
If your brakes are working fine (no vibration when braking) I certainly would not change the rotors. Some people say you should turn the rotors at every pad change. I say if you turn them, even when they don't need turning, you are shortening the life of the rotors (making them thinner) each time they are turned for no good reason.
Old Aug 13, 2006 | 04:07 PM
GreddyAccord99's Avatar
i recently jus changed my rotors and pads, and i had vibration when i braked. when ym mechanic was putting the rotors and pads on, he took the rotors and showed me and said thats why your car was vibrating when braking and he showed me how the pads were worn so close to the metal, and i figured if im replacing the pads, might as well do the rotors as well so you can keep track of everythin.
Old Aug 13, 2006 | 04:30 PM
philadd's Avatar
Default Re: (GreddyAccord99)
I have yet to change my rotors... and I'm on my 4th set of brake pads.
teggy2154
Jul 21, 2021 02:36 PM
PetroGuyX
Jun 26, 2003 02:10 PM
LudeyKrus
Jun 10, 2003 03:40 PM
Trellis
Mar 12, 2003 04:50 PM
illusion
Apr 10, 2002 09:31 AM
