trouble setting cam gears to tdc
Old Aug 13, 2006 | 02:39 AM
integlstrike1's Avatar
Default trouble setting cam gears to tdc
i just changed my timing belt and im having trouble setting my cam gears to tdc. if i wanna move it a couple teeth, the cam gear just goes back to it original spot. do i gotta take the cam gear off then set it tdc, or do i gotta align the cams key with the cam gear key...anyone know the procedure??
Old Aug 13, 2006 | 05:18 AM
Duane_in_Japan's Avatar
Default Re: trouble setting cam gears to tdc (integlstrike1)
You need a friend to hold the cam fromturning while you install the belt, tension the belt and then turn the crankshaft two full revolutions and see if your timing marks all the way around are still aligned on the gears and on the engine block and heads.
Old Aug 13, 2006 | 07:45 AM
lVlemphizStylez's Avatar
Default Re: trouble setting cam gears to tdc (Duane_in_Japan)
use two 5 mm punches and put them through the cam plates and the cam shafts...itll lock them at exactly tdc
9honda5civic
Oct 10, 2012 03:21 AM
DMCCOY
12
Jan 9, 2009 08:39 PM
sph33r
Feb 19, 2006 09:53 AM
HamiltonRex
Nov 13, 2004 05:50 PM
Black96Cobra
Oct 28, 2001 11:06 PM
