h22 in eg question?
i just got a hold of a h22 swap and i am going to put it in my 92 eg and i wanted to know what kind of suspension you guys suggest for the car cuz everyone has told me that my handleing with going to suck and the other question is about the clutch kit my friend keeps yapping to me about getting a RPS clutch kit cuz there great i guess. what do you guys think is it good choice for a h22 that going to be turbo'd shortly, if not what are some good streetable kits you suggest?
thanks for your time any suggestions will be greatly appreciated
thanks
nick
thanks
nick
The handling shouldnn't be that bad with a decent set of springs and struts. I have driven 2 H22 Civics and an H22 Integra, not super hard at the handling limit but railing some corners for sure and everything seemed pretty much the same as a car with a B-series.
For the clutch I would go with an ACT extreme pressure plate with a street disc.
Turbo setup, I'd build my own, but that's just me.
if you can afford RPS get one.
And I run teh ACT extreme and the pedal pressure gets old pretty fast, If I could do it over I would get a Competition Clutch stage 3 or 4 instead.
Also use the search function as well there is ungodly amounts of info on this swap. Someone even measured the weights of H vs B series. An h22 is probably around the same weight as a b18c with turbo kit...which means that if an H in a civic makes it a handling pig then just about every turbo B is a handling pig too.
THE SAME ONE'S THAT I HAVE
IN MY H22 1993 CIVIC SI H/B
