Suspension & Brakes Theory, alignment, spring rates....
would 96-00 civic shocks fit my 93 civic
Old Aug 12, 2006 | 07:01 PM
Mistermark's Avatar
Default would 96-00 civic shocks fit my 93 civic
as the title says
ive been offered for a good deal shocks that supposedly fit 96-00 Civics
just wondering would they fit? cuz i have a 93 civic hatch
thanks
Old Aug 12, 2006 | 07:37 PM
Voyage34's Avatar
Default Re: would 96-00 civic shocks fit my 93 civic (Mistermark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by another thread from 2 days ago asking the SAME QUESTION &raquo;</TD></TR><TR><TD CLASS="quote">the ek uses narrower bushings in the lca that the shock mounts to.
you will have to grind the bushings down in order to make the ek shocks fit.
you will have to do this every time you replace the bushings as long as you are using those shocks.
or you could buy the parts specifically for your car.</TD></TR></TABLE>
Old Aug 13, 2006 | 05:51 AM
Mistermark's Avatar
well, (sorry i dunno the name of it)
the bracket that attachs the bottom of the strut to the LCA, couldnt it be swapped right onto the 96-00 struts, unless that diameter is a diff. size.
unless your talking about the rear shocks, cuz u cant swap the brackets
Old Aug 13, 2006 | 06:48 AM
Voyage34's Avatar
Default Re: (Mistermark)
oh, fronts? im under the impresson they fit 92-00, the only issue ive ever heard about was regarding the rear bushing.
Old Aug 13, 2006 | 07:52 AM
Mistermark's Avatar
ok thanks for the explaination
Old Aug 16, 2006 | 08:40 PM
ToonMOG's Avatar
I know your question has been answered but I would like to say that I have almost the identical situation (except that I own the shocks)... and the only problems you will run into are the LCA bushings as Voyage34 said, and the other problem you will run into is that your stock front shocks have a brake line holding bracket attached to it, so you will have to deal with that brake line in some kind of way... but that's not as serious as the bushing. (by the way I'm trying to develop a solution to that problem.... I think I'm going to attach the bracket to the damper fork... any sugestions would be great ^_^ )
Jimmy
Suspension & Brakes
Jul 17, 2007 10:15 PM
TheIntegraGuy
Jan 17, 2005 08:04 AM
fsck3r
Jun 4, 2004 08:42 PM
1 speedstar
Feb 11, 2002 11:14 PM
