CRX won't shut off!
Well, this came up because of the wire tuck. I fixed the one code I had (mispinned a plug), but now I've still go the problem that the car turns on, but not off.
Done a fair bit of testing so far, here's what I've got:
- The wiring on my push button start is identical to what it used to be
- All the wires on the relocated fuse box are going to the correct places.
- the ignition wiring that I tucked is all together and ****
- the black/yellow to the ignitor gets no power in I with the engine off, but power in II with the engine off
- I can turn the key and pull it out but the engine doesn't quit.
Any help? thanks!
Any help? thanks!
Wow, completely stumped (I'm not neccessarily a wiring Guru) but I'll give CRXBart a call and see what he thinks, but if you havent already hit up EF8Kid, he's the resident wire tuck king around these parts
Jstnj03
Apr 26, 2008 11:07 AM
