D Series into 00 Civic SiR?
I need my car running and my new motor wont be running for a while. IMy buddy just put a B16a in his 97 EX. What will it take to put his single vtec swap and **** into my 00 Civic SiR?
Just use all the mounts, axles, shift linkage, etc etc from the single cam.
You do need to reuse your stock '00 engine harness(cant use the '97).
Then you need an obd2B-obd2A jumper harness to plug in the '97 ex ecu.
I have a p28 and a conversion harness for it. So all need to use is the mounts from the single and the lnkage correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR »</TD></TR><TR><TD CLASS="quote">I have a p28 and a conversion harness for it. So all need to use is the mounts from the single and the lnkage correct?</TD></TR></TABLE>
Mounts, shift linkage, and axles.
You still need to reuse your stock engine harness on the sohc, though.
swaplighter
May 15, 2004 10:56 PM
civicudesire
Mar 15, 2003 03:50 PM
