Changed valve cover gaskets and spark plugs = blue smoke out exhaust?
Old Aug 12, 2006 | 10:06 AM
Diversion's Avatar
Default Changed valve cover gaskets and spark plugs = blue smoke out exhaust?
What gives? All I did was change the valve cover gasket, upper sparkplug gaskets and sparkplugs.. put it all back together, blue smoke out the back and pretty bad.. I did have quite a bit of oil in the sparkplug chambers.. would this be the reason? Is the engine having to blow it out the exhaust now?
I don't see how a sparkplug change would cause a ring to blow.. pssh..
Edit: Also changed PCV valve..
Oil get on the electro part of the plug maybe? Since I wasn't able to clean out all of the oil in the chamber, I suppose the firing end could have gotten a little oil on them.. I hope that it clears up.. it's pretty bad.
Jay
Old Aug 12, 2006 | 10:39 AM
nastynutsnash's Avatar
Default Re: Changed valve cover gaskets and spark plugs = blue smoke out exhaust? (Diversion)
yes pil more then likely dripped down, just drive it around and it should quit once the oil is all burned up
Old Aug 12, 2006 | 11:10 AM
Diversion's Avatar
Yep, that was it.. drove around a little bit and it cleared up.. all good now, thanks!
90hondaccord
May 25, 2014 10:42 PM
Jax4gencivic
May 4, 2006 07:59 AM
froger
Feb 3, 2005 12:39 PM
elpermgrande
Oct 18, 2002 04:42 PM
shingles
Dec 22, 2001 07:28 AM
