Speed sensor
Old Aug 12, 2006 | 09:04 AM
powerpro_69's Avatar
Default Speed sensor
I have a 90 CRX DX and a B16A1 what speed sensor do i need to get or what do i need to do to make it work
Old Aug 12, 2006 | 09:10 AM
USDMSiR's Avatar
Default Re: Speed sensor (powerpro_69)
90-93 DA integra
Old Aug 13, 2006 | 05:59 AM
Default Re: Speed sensor (USDMSiR)
so i just ues the sensor or do i have to change clusters and does anyone have on for sale
Old Aug 13, 2006 | 06:11 AM
USDMSiR's Avatar
just install the cable speed sensor, plug the cable in and it should just plug straight into the back of your usdm cluster.
Old Aug 13, 2006 | 10:47 AM
well it got cut when we pulled the motor out guy thought i had a new one
Old Aug 13, 2006 | 02:43 PM
USDMSiR's Avatar
just pick one up from a junkyard or the dealership. i actually might have a brand new one sitting in my garage if you want that.
Old Aug 14, 2006 | 05:08 AM
yeah see and let me know how much u want
Old Aug 14, 2006 | 05:12 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerpro_69 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 CRX DX and a B16A1 what speed sensor do i need to get or what do i need to do to make it work</TD></TR></TABLE>
you can use the stock one,works fine just pop it out the old tranny and into the new b16 tranny
Old Aug 14, 2006 | 01:29 PM
USDMSiR's Avatar
Default Re: Speed sensor (Mr.speaker)
are you sure? i heard you have to have the b series speed sensor and the only usdm b series cable vss's are out of 90-93 integras
Old Aug 14, 2006 | 08:06 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMSiR &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? i heard you have to have the b series speed sensor and the only usdm b series cable vss's are out of 90-93 integras</TD></TR></TABLE>
yes im 100% sure,,been doing honda swaps for a while..
Old Aug 14, 2006 | 08:43 PM
well it got cut when we pulled the motor out guy thought i had a new one so i need a new one any way
Old Aug 14, 2006 | 10:56 PM
salman's Avatar
If i want to replace my electrinic Vss with Cable speed sensor, will it be ok
Old Aug 14, 2006 | 11:10 PM
bag's Avatar
bag
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">If i want to replace my electrinic Vss with Cable speed sensor, will it be ok
you mean the other way around right? cause you know our cars come with cable...But if you use electric then you gotta use a different gauge cluster like from a 94 teg or 96 civic .etc anything that is electric
Old Aug 14, 2006 | 11:21 PM
salman's Avatar
Default Re: (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">
you mean the other way around right? cause you know our cars come with cable...But if you use electric then you gotta use a different gauge cluster like from a 94 teg or 96 civic .etc anything that is electric</TD></TR></TABLE>
In my B16a there Vss was electrical, but my cluster is cable oprated,
I was thinking if I replace it with cable system,
Old Aug 14, 2006 | 11:55 PM
bag's Avatar
bag
oh yes...replace it with a cable or get a different cluster....Vtec doesnt even work on your motor huh? seeing how it needs speed reading to engage vtec
eh3milio
Transmission & Drivetrain
Sep 30, 2013 06:56 PM
B16CRXVTEC
22
Oct 4, 2011 06:27 PM
maka
Oct 6, 2005 07:59 AM
iTzKeviN
Aug 12, 2005 01:10 PM
85mm LS VTEC
May 24, 2005 08:06 PM
