H22 Timing belt installation- HELP!
Old Aug 12, 2006 | 08:07 AM
nisecurrie's Avatar
Default H22 Timing belt installation- HELP!
Is there a trick to installing this belt? I can't get enough slack in it to get it on!
Old Aug 12, 2006 | 08:11 AM
bb_one's Avatar
Default Re: H22 Timing belt installation- HELP! (nisecurrie)
Just keep playing with it. If you've switched over to the manual tensioner, relieve the tensioner spring to give you more slack to play with.
What I normally do is get about 1/8" of the belt on all sprockets then move the belt on the cams halfway on. After that I would gorilla the belt on the crank sprocket. Usually takes me about 10mins to get the belt on (3rd) time installing the t-belt. Using pin punches to keep the cams still is also very useful.
Old Aug 12, 2006 | 01:10 PM
nisecurrie's Avatar
Default Re: H22 Timing belt installation- HELP! (bb_one)
Thanks! You have given us a direction to go and I apprecaite it
Old Aug 12, 2006 | 09:22 PM
RJonathan's Avatar
what i do is relieve the tension on the tensioner, then put the belt on the crank sprocket, and then slip about 1/4 in on the exhaust cam, then on the intake cam I bend the belt back alittle bit until I can get it onto the intake gear then once its on, I just slide everything in.
Old Aug 12, 2006 | 10:40 PM
Eddiebx's Avatar
did u remember to reset the auto tensioner to the shortest position? if you just pulled off the belt and didnt bother to screw the auto tensioner back in, theres no way in hell your gonna get the belt on.
Old Aug 13, 2006 | 06:22 AM
Duane_in_Japan's Avatar
Default Re: (Eddiebx)
Put the belt on the cam and crank gears then turn the cams and crank in opposite directions to tighten the belt opposite to the tensioner and this will creat slack on the tensioner side.
For example turn the crank CW and turn the cams CCW, the belt opposite to the tensioner will tighten and simultaniously will creat slack on the tensioner side, I may have gotten CW & CCW backwards.
Can you remove the tensioner pulley and get it behind the belt and then install the pulley or the tensioner / pulley set.
freshCROOKS
Aug 14, 2012 06:38 PM
vinuneuro
Sep 17, 2008 04:11 AM
kornerk12
Nov 25, 2007 02:03 PM
huge230
Oct 4, 2005 12:31 PM
AdamITR
Aug 28, 2002 07:11 PM
