My RPM gauge isn't working...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">Spped sensor is for the speedometer and not the rev counter/tach. Rev counter takes its signal from the distributor (AFAIK) via the ECU.</TD></TR></TABLE>
Check your engine grounds first. Then ensure your cluster connections are not loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">Rev counter takes its signal from the distributor (AFAIK) via the ECU.</TD></TR></TABLE>
Correct. The blue wire.
when my tach stopped working it was cause of my Dizzy, and I never figured out why...sorry man lol, but thats all I got for you other than check all your connections in your cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eaglclon »</TD></TR><TR><TD CLASS="quote">already tried the speed sensor. it's not it. speedo still works</TD></TR></TABLE>
Why would you check the speed sensor...it has nothing to do with the rev counter/tach. Read the rest of the posts above
michaelsej1
12
Sep 27, 2010 06:18 PM
Average Al
Jan 22, 2004 04:13 PM
Nextelbuddy
18
Jun 14, 2003 06:12 AM
