TEIN SS and cutting bumpstops
Hey guys i have a 91 crx and recently bought some used tein ss from a friend. I went from prokit with blues to this. My question is im new to coilovers, do u have to cut the bumpstops or are they pretty much setup for whatever ride hide u decide to put ur car at. Also do teins have a shorter shaft for adjusting ride height
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED7 »</TD></TR><TR><TD CLASS="quote">You don't cut the bumpstops. The tein's have the height adjustment with the shock body instead of the spring perch(like gc etc.). So don't touch the spring perch part.</TD></TR></TABLE>
not on the SS. that system is only on the newer tein suspensions like the FLEX.
generally speaking the bumpstops should be trimmed by about 66% to about 1.5" or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey »</TD></TR><TR><TD CLASS="quote">
generally speaking the bumpstops should be trimmed by about 66% to about 1.5" or so.</TD></TR></TABLE>
should you cut them from the bottom or the top of the bumpstop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">from the bottom up. The lower you go, the stiffer bump you want it.</TD></TR></TABLE>
i plan on raising it up but i still might do this. should i do as said before and cut 1.5 inches?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen »</TD></TR><TR><TD CLASS="quote">
i plan on raising it up but i still might do this. should i do as said before and cut 1.5 inches?</TD></TR></TABLE>
cut it until it's about 1.5" tall.
i plan on raising it up but i still might do this. should i do as said before and cut 1.5 inches?</TD></TR></TABLE>cut it until it's about 1.5" tall.
