Balance shaft assembly
Old Aug 11, 2006 | 05:41 PM
wheelmaneg6's Avatar
Default Balance shaft assembly
I already ready did the auto tensioner fix to manual, If i am not running my balance shafts, the balance shaft tensioner and spring assembly i do not need to put on my engine , because it will be just sitting there. right?
Old Aug 11, 2006 | 05:55 PM
MLBZ521's Avatar
Default Re: Balance shaft assembly (wheelmaneg6)
You have to have them there or have to have something to take up the space, a spacer. It's probably just better to use the stock stuff as you'll have the correct distances so there isn't anything that's mis-aligned..
Someone else correct me if I'm wrong.. I think I know what he means, but not sure..
Old Aug 11, 2006 | 06:42 PM
Layziejoe775's Avatar
Default Re: Balance shaft assembly (MLBZ521)
i did the same thing...everything seems working the same where i did the h23 manual teinsoier...however now...it starts to shake at a certain mph like 65..i don't know if it's wheel alignment or wheel balance....but i might think it's the balance pullies that i left alone without the belts...help me!
Old Aug 11, 2006 | 06:44 PM
PrecisionH23a's Avatar
I always leave the OEM balance shaft bearing on. No problems yet.
tnt1197
10
Dec 1, 2013 06:15 PM
SOHCvtakdude
Dec 8, 2010 02:41 PM
xtokex
Nov 12, 2007 07:14 PM
blackoutcivic
Jul 17, 2005 12:55 PM
dutchman5
Jan 14, 2003 11:12 AM
