OBD 1 ERROR CODES
Code 8. TDC sensor (Top Dead Center).
That sensor is inside your distributor. you more than likely need a new dizzy. i would first check the wiring. make sure no opens or shorts. then i would check signal from it. or you can swap in a known good one and see if you still have a problem.
nicwin
Sep 27, 2018 07:54 AM
