How to put a chip in
Old Aug 11, 2006 | 03:43 PM
str8JDMteggy's Avatar
Default How to put a chip in
I was trying to put a chip in my 94 gsr ecu and in the instrustions it says put the chips in which i did and to put a jumper on j10. There is no j10 where the instrustions say to put the jumper and next to it there is a j1. So im wondering if anyone has put a chip in before and had the same problem.
chris
Old Aug 11, 2006 | 05:08 PM
Uncle Willie's Avatar
Default Re: How to put a chip in (str8JDMteggy)
ebay chip?
Old Aug 11, 2006 | 05:27 PM
iH8RICERZ's Avatar
Default Re: How to put a chip in (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">ebay chip?</TD></TR></TABLE>
sounds like it......
basically, you add a jumper to the j1, solder in the 74hc373 rom to its location, solder in the socket, then plug in the chip making sure its going in the right direction. There is a notch on one end of the chip...this end should be facing towards the plug/harness of the ecu.
Old Aug 11, 2006 | 07:24 PM
Ichigo's Avatar
and then it blows up your motor in two to three weeks.
Old Aug 11, 2006 | 07:56 PM
Rikter's Avatar
Yep.
Ebay chips suck.
-Rik
Old Aug 12, 2006 | 12:23 PM
Yeh ive heard that these chips suck but also a lot of people run these chip wth no problems. Where did these chips get such a bad name and what has happened that makes them so bad.
Old Aug 12, 2006 | 12:29 PM
cm zak's Avatar
Ebay happened.
Old Aug 12, 2006 | 12:44 PM
iH8RICERZ's Avatar
Default Re: (str8JDMteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8JDMteggy &raquo;</TD></TR><TR><TD CLASS="quote">Yeh ive heard that these chips suck but also a lot of people run these chip wth no problems. Where did these chips get such a bad name and what has happened that makes them so bad.</TD></TR></TABLE>
massed produced, generic map that basically dumps HELL OF A LOT OF unused fuel, causing your motor to run very rich, even some times causing damage. Plus, there's a guy in the all motor forum who bought one of these ebay chips, as well as the turbonator, then hopped on the dyno. He lost power with the ebay chip, and lost power with the turbonator....posted dyno graphs, case closed.
Old Aug 12, 2006 | 01:19 PM
All i wanted was a chip so i could rev a little higher.
Old Aug 12, 2006 | 02:25 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8JDMteggy &raquo;</TD></TR><TR><TD CLASS="quote">All i wanted was a chip so i could rev a little higher.</TD></TR></TABLE>
thats a stupid reason to chip it
Old Aug 12, 2006 | 04:05 PM
Then whats a good reason?
Old Aug 12, 2006 | 05:36 PM
Adambomb's Avatar
Because you want to tune it and get the most power out of your engine after you've put quality parts in it, not rev higher.
Old Aug 12, 2006 | 09:54 PM
PrinceAli132's Avatar
Why would you want to rev higher? Have you upraded you valvetrain, and have other work done where you actually make power that high? Otherwise there's no reason to rev higher than the recommended redline.
Ali
prelude_93vtec
Jan 26, 2007 06:50 PM
austincrx
Jul 14, 2006 02:24 PM
1991hondahatchsi
May 26, 2006 07:19 PM
88cerx
Dec 11, 2005 07:42 PM
russian_racer
24
May 2, 2003 07:37 AM
