no oil pressure
Old Aug 11, 2006 | 03:09 PM
bOOsT-FeIn's Avatar
Default no oil pressure
ok i have abolutely no oil pressure what so ever, my oil light is on and if i take off my oil filter nothing will come out so i was told i need to replace my oil pump but i do not know if any thing else can be wrong inside. do you think if i replace my oil pump on my b16 my oil pressure will return with no problems or should i just say expletive it and get another block
Old Aug 11, 2006 | 03:14 PM
s_vares's Avatar
There could be many problems. YOu muct pull off the oil pan 1st to see if there is anything blocking the oil pickup or screen. The pump can be removed and inspected if the pickup is clean. If those both pass the test the problem lies in the bottom end bearings.
If this motor has been ran without oil pressure it may be too late. Is it high milage and worth fixing? Check this out. Pill off a bearing cap and see the condition and platiguage them.
Steve
Old Aug 11, 2006 | 03:22 PM
s_vares's Avatar
sorry about all the spelling errors im tired
Old Oct 29, 2006 | 01:28 AM
jdm_ekcivic's Avatar
Default Re: no oil pressure (BrAiNdEaD247)
I've got the same problem. No oil pressure at all. Car won't start either.
Old Oct 29, 2006 | 09:07 AM
VtecnTurbo's Avatar
Default Re: no oil pressure (jdm_ekcivic)
is it after a motor swap? o rit just wont start after it ran fin ethe prior day. when you remove the oil pump you can look down the passage to see if there is anything that may have fell into the passage.
i had pressure and it dropped to 0 i shut the motor down checked everything started up still 0psi so i took of the oil pan and i had sludge and debree from the fresh rebuild cleaned ou t the pick up and oil pan swapped filter and it was golden
Old Oct 29, 2006 | 02:14 PM
Default Re: no oil pressure (VtecnTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecnTurbo &raquo;</TD></TR><TR><TD CLASS="quote">is it after a motor swap? o rit just wont start after it ran fin ethe prior day. when you remove the oil pump you can look down the passage to see if there is anything that may have fell into the passage.
i had pressure and it dropped to 0 i shut the motor down checked everything started up still 0psi so i took of the oil pan and i had sludge and debree from the fresh rebuild cleaned ou t the pick up and oil pan swapped filter and it was golden</TD></TR></TABLE>
It is a swap, but it's been running fine for 5 years prior. Just out of the blue, bam, no power. When I call the dealership, I'll mention that idea.
Old Oct 29, 2006 | 04:02 PM
bsixteen's Avatar
may sound stupid but you never mentioned it. when was the last time you changed your oil?
Old Oct 29, 2006 | 04:09 PM
NJIN BUILDR's Avatar
Broken oil pump rotor for both of you.Aftermarket crank pulley?
Old Oct 29, 2006 | 04:18 PM
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">may sound stupid but you never mentioned it. when was the last time you changed your oil?</TD></TR></TABLE>
The next oil change is coming up in about 100 miles, so it's not like it's overdue or anything.
Old Oct 29, 2006 | 04:19 PM
Default Re: no oil pressure (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Broken oil pump rotor for both of you.Aftermarket crank pulley?</TD></TR></TABLE>
Please tell me that's not super expensive to fix.
Stock crank pulley.
Old Oct 29, 2006 | 07:12 PM
VtecnTurbo's Avatar
about 90 bucks or so for the pump, the pain in the dyk is taking everything off to get to it
give yourself about 4-6 hours to do it
Old Oct 30, 2006 | 06:00 PM
Update: The Dealership said it was the timing belt. That makes no sense with the oil light coming on, but whatever.
ndex
Jan 28, 2013 06:31 AM
wezzel19
Oct 9, 2006 09:05 AM
tcontesh
Jun 29, 2006 01:46 PM
crxsiperf
Nov 23, 2005 04:36 PM
vtec.dc2
Feb 1, 2004 10:49 AM
