headunit mounting help
well i have a JVC headunit ucrrently and it is not mounted. it is just resting on my console and the metal bracket in the back of the part were the console screws on to. how do it make it so that the headunit is mounted properly and held in place. i have the mounting bracket and the sleeve but the holes on the factory metal piece behind the console wont line up with holes in the headunit. what should i do?
The sleeve for the head unit should have little tabs, put the sleeve in place then push them little tabs. That should be sitting tight with no movement, after hooking up all your wires just push the head unit into the sleeve.
so youve got the plastic piece from Metra or whoever that your cage mounts to?
all you need after that is a couple of screws to mount the plastic piece. In my case, I lost the plastic white squares that honda screws will thread into, so I used some carriage bolts and nuts and installed them backwards. If you need pics, I'll take some. Just let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saaron34 »</TD></TR><TR><TD CLASS="quote">so youve got the plastic piece from Metra or whoever that your cage mounts to?
all you need after that is a couple of screws to mount the plastic piece. In my case, I lost the plastic white squares that honda screws will thread into, so I used some carriage bolts and nuts and installed them backwards. If you need pics, I'll take some. Just let me know.</TD></TR></TABLE>
yeah dude im still lost. i tried to do it today but it didnt work. pics would be appreciated. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">I had the same problem with my pioneer unit, went on ebay and searched "stereo sleeve" and bought one with the trim and it fits perfects.</TD></TR></TABLE>
my question is how do you have it mounted. what kind of screws,brackets, etc are you using to keep it secure? i already have the sleeve and trim piece.
Modified by 4g4d at 9:51 PM 8/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Ah, well, mine's perfectly snug just slapped in the sleeve in the whole,
ohh gee thanks
. any pics?
</TD></TR></TABLE> ohh gee thanks
. any pics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">tomorrow when it's bright outside and such,
okaley dokaley
</TD></TR></TABLE>okaley dokaley
sorry about the wait.
In this picture, you can see the cage with the bendable tabs (yes I know I missed a tab). This is pressed up against the black plastic bezel. the black plastic bezel is held to the car by two of those big ol carriage bolts with a nut. This really provides no extra security, I just used them because I did not have the regular honda screws and the plastic squares to thread into.
once you mount the plastic bezel to the car, that is enough to secure it.
**edit: to make it easier on yourself, mount the bezel/cage you assembled FIRST, then slide the stereo in it. It will snap into the cage perfectly if you have the correct cage for the stereo. (This is unless you modify this assembly to make it difficult for theives. youll know what im talking about once you look at it.
From: I told you to wait in the truck in Texas, United States
Try a place that installs stereos or on line..
at http://www.crutchfield.com/S-WdHJSIqGNNb/
You can also usually find the stuff at Best Buy
if you talk to the stereo installers..
Also see: http://www.installdr.com.
and http://www.the12volt.com/com/
I actually got that one from Best Buy. Costed me about 15 if i remember correctly. Installer.com has a lot of good stuff too (but not that particular bracket, oddly enough).
Metra is the brand name. just go to Best Buy and tell them you need the plastic mounting peice for a stereo in a 1990 civic. the part that mounts to the car.
looks like all three of those above sites dont have what he needs.
if THAT doesnt work, then I'll have to see what part number my bracket is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d »</TD></TR><TR><TD CLASS="quote">hey man i really appreciate your help. do you have any front shots of your console with the headunit in it ?</TD></TR></TABLE>
not assembled. when i get a chance, I'll take a picture.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennisraymondhall »</TD></TR><TR><TD CLASS="quote">i'll sell you the plastic bezel for 12.00 shipped</TD></TR></TABLE>
will it work with a regular in-dash JVC unit? if so can you overnight it and ill paypal you the money.
maybe its old news now, but here is the picture of everything assembled.
the stuff in the ashtray area was actually my cd changer control mount when i had a cd changer. Yes it is made out of Erector. You'd be surprised what Erector is compatible with in our cars!
I'm thinking of making a cellphone mount in that spot at some point.
Page3905
Aug 27, 2012 11:26 AM
crx98
Mar 18, 2004 12:21 PM
Skeletor
May 12, 2003 03:37 PM
