SRS light on all the time, '02 accord EX V6
Could be the control unit, you might check for recalls . the other common problem is the clockspring under the steering wheel. it would be way cool to know what code is stored in the control unit
anywhere I can check for recalls, that won't cost money to look them up? I have looked around and can't find anything. Also, the car is out of warranty... so will they repair a faulty SRS component on a 2002 car with 110k miles? Not for free, I assume, but are discounts on items like this common if it's a common problem? I've mainly dealt with BMWs, where the dealership generally tells people to go F themselves, lol. Thanks in advance,
-tim
Modified by Tim 95 M3 at 3:59 PM 8/12/2006
-tim
after more searching i found a good website for recalls/TSBs... http://www.carcomplaints.com , hope you guys like it.
Question bout a clutch problem. Just replaced the master cylinder and the clutch is just staying pressed to the floor because I cant get any pressure in the line what should I do?
Slo-STI
Nov 11, 2011 06:05 PM
moddhu
Sep 13, 2008 05:24 PM
