amp install question...
Alright, i've got a 2006 honda civic, i'm hooking up an amp with an adjustable output adapter which converts speaker output to RCA pre-amp. I'm using this because I am keeping my factory radio installed. Since I don't know where to begin ripping apart the dash to get behind the radio, I am going to hook this output adapter up to the rear speakers in the trunk. The problem is, I don't know which wires are negative/positive. It just doesn't say back there. I've done some searches, called honda and car stereo places, nobody can help me. Told me to buy a wiring diagram book. Might as well just pay to get it installed!! The right rear speaker has orange and blue wires running to it and the left rear has brown and grey. Anyone know which wires are negative/positive?
Try http://www.installdr.com for your wiring colors... I know their diagrams won't cover the '06, but the colors are the same...
Also, if you're installing your converter back there, buy a short RCA cable to go from the amp to the converter... Don't just use a 17' cable and coil it up. That's one way noise can enter the system... Use a cable long enough to do a clean install, but not too long that you have to coil the excess...
also, the converter has 2 brown wires, i believe they are used for grounding? are they necessary?
and will my amp power up if i don't have this connected, just want to test the power to see if i have a good place to ground
Hmmm.. Maybe they did change wire colors for the '06s... I don't have a new chart... Maybe FCM does.. We'll just wait for him to post..
As far as the converter goes, you only need to ground the brown wires if you have noise issues....
And yes, the amp will power up without the converter connected..
patrickvertigo
Audio / Security / Video
10
Feb 14, 2013 06:41 AM
88CRXJ
55
Oct 6, 2009 03:37 PM
Jay J
Sep 24, 2008 04:20 PM
