performance valve train.... best hp gains!!!!
Old Aug 11, 2006 | 12:17 PM
xxmikexx206's Avatar
Default performance valve train.... best hp gains!!!!
hey everyone, i have a zc mini-me with a d16z6 vtec head.... valve train is the only thhing performance i need now so i would like to have everyones opinion on which valve train packages have the best and most dramatic horse power gain.... all help is appreciated
Old Aug 11, 2006 | 12:49 PM
drSquish's Avatar
Since when do you get horsepower from an aftermarket valvetrain on a stock engine?
Old Aug 11, 2006 | 01:23 PM
Fobtions's Avatar
Default Re: (drSquish)
yah valvetrain upgrades are considered a safegaurd against valve float when using high lift and duration cams.
the cams are what determine whut power u are gonna get
Old Aug 11, 2006 | 01:26 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">yah valvetrain upgrades are considered a safegaurd against valve float when using high lift and duration cams.
You might get mircoscopic amount from less wieght in vavle train.
The cam is the mechianal brain of the motor, you'll have to upgrade your cam as well.
Also a better valve train will be part of spinning higher for larger cams, most larger cams only make higher rpm power.
OP Is the head all stock? If not whats in it? What are your goals out of it?
Old Aug 21, 2006 | 02:13 PM
Default Re: (***-assin)
well..... for everyones well being, my engine is NOT stock!!!! anyways I KNOW that the cam is where the horse is, although I NEED TO KNOW WHICH VALVETRAIN PACKAGES ANYONE AND EVERYONE HAS HAD THE BEST WORK WITH, I NEVER ASKED for someone to go and put words in my mouth and say i have a bone stock motor trying increase my horsepower by replacing my valves and springs.... so if anyone can recomend a valvetrain for a NON-STOCK motor i would highly appreciate it
Old Aug 21, 2006 | 03:51 PM
91SiZ6's Avatar
You should match the manufacturer of your cam and valve springs. They're designed to work perfectly together. Example, I have a Comp Cams cam and matching valve train. You won't get any horsepower from it, though.
Old Aug 21, 2006 | 03:53 PM
SIred91's Avatar
Rainman
Default Re: (91SiZ6)
Supertech for the win. srsly.
Old Aug 23, 2006 | 03:30 PM
thej0hnster's Avatar
Default Re: performance valve train.... best hp gains!!!! (xxmikexx206)
Carillo
Old Aug 23, 2006 | 03:35 PM
Ass$nyper's Avatar
Default Re: (xxmikexx206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmikexx206 &raquo;</TD></TR><TR><TD CLASS="quote">well..... for everyones well being, my engine is NOT stock!!!! anyways I KNOW that the cam is where the horse is, although I NEED TO KNOW WHICH VALVETRAIN PACKAGES ANYONE AND EVERYONE HAS HAD THE BEST WORK WITH, I NEVER ASKED for someone to go and put words in my mouth and say i have a bone stock motor trying increase my horsepower by replacing my valves and springs.... so if anyone can recomend a valvetrain for a NON-STOCK motor i would highly appreciate it</TD></TR></TABLE>
wow.....
I weep for humanity.
You'll want to match drivetrain parts as 91siz6 said. Not always is it just matching brands but making sure your springs etc will take the lift and rpm of the cam you pick.
99black_em1
43
Mar 3, 2009 09:27 PM
Scubster
Apr 26, 2007 03:14 PM
musTerdh22eg
Mar 14, 2006 11:29 PM
hondatuner20
Jun 7, 2005 01:52 PM
