Suspension & Brakes Theory, alignment, spring rates....
Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic
Old Aug 11, 2006 | 09:32 AM
Fuster_Cluck's Avatar
Default Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic
I installed my LS trailing arm assembly. E brake cables are installed, everything ready to go except....
I just need to remove the old VX lower brake line "A" to connect the LS brake lines. Is there a trick to removing the clip located in the 2nd pic? I looked in the Helms manual and it looks to just slide straight back. However I have tried pulling it back with no movement from the clip. Should I try twisiting it first? The helms suggests to replace the clip once removed, but not sure if this is necessary.
Thanks for any help
Car is a 95 VX
Old Aug 11, 2006 | 09:35 AM
gldndrgn14's Avatar
Default Re: Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic (Hybrid93Hatch)
spray it down with pb blaster or wd 40 to loosen out the dirt and stuff. then get a good pair of needle nose pliars, grab the lip of it, and wiggle it back and forth and loosen it out. it will come out.
Old Aug 11, 2006 | 09:37 AM
Default Re: Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic (gldndrgn14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 &raquo;</TD></TR><TR><TD CLASS="quote">spray it down with pb blaster or wd 40 to loosen out the dirt and stuff. then get a good pair of needle nose pliars, grab the lip of it, and wiggle it back and forth and loosen it out. it will come out. </TD></TR></TABLE>
Have all 3!
Will do, thanks for the info
Old Aug 11, 2006 | 10:41 AM
94eg!'s Avatar
#1 Super Guy
Loved
I used flat nose pliers (see pic) to grab the tab that is sticking upward. Basically the pliers are pointing downward. Then lever the pliers toward the chassis (against the brake hose) to lever the clip away. This works really well...
Old Aug 12, 2006 | 10:57 AM
SlowEgg's Avatar
I use needle nose "vice grips", and adjust it to where it JUST grabs the clip on both sides, so you can pull it straight out. If it is the first time coming out, it will be fairly sticky.
BTW that is VERY clean!
Old Aug 12, 2006 | 11:23 AM
Default Re: Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic (SlowEgg)
Thanks guys for the tips/info. I was able to remove the clips without damaging them, installed the new lines, bleed all the brakes, and took the car around the block.
I'm going to upgrade the master cylinder next and bleed the system again.
I cleaned the entire trailing arms before installing. I was going to paint them black but after seeing how clean they came out and how much of a PITA it was going to be I decided not to paint them.
I will be painting the LCA's and OEM sway bars before installing though.
Old Aug 13, 2006 | 06:37 PM
Eddiebx's Avatar
i just use a screwdriver or pry bar to pry it off, why waste the engery tugging and wiggleing, when u can just pry it out,
Old Aug 13, 2006 | 07:03 PM
SlowEgg's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">i just use a screwdriver or pry bar to pry it off, why waste the engery tugging and wiggleing, when u can just pry it out, </TD></TR></TABLE>
because using the vice grips, you dont risk bending it. i tried a screwdriver first when i did mine, and it got bent. vice grips/pliers keep it looking new.
prjct92eh2
Acura TSX
Mar 24, 2009 06:42 PM
bjfisher
Suspension & Brakes
Feb 3, 2006 04:41 PM
antivic
Jun 28, 2005 10:51 AM
civicd15b2
Mar 29, 2005 02:40 PM
Diamond
Feb 27, 2003 07:46 AM
