Clutch Slave Cyl. - What lube to use?
Old Aug 11, 2006 | 03:00 AM
EnjoyTheRideDC2's Avatar
Default Clutch Slave Cyl. - What lube to use?
Ok, I've searched on the squeaking sound coming from my clutch slave. Now my question is, what type of grease should I be using to lube the end of the slave that contacts the fork and the shaft itself?
I hear Wheel Bearing Grease, Caliper Grease, and High temp urea grease...Which is correct?
Old Aug 11, 2006 | 12:39 PM
Default Re: Clutch Slave Cyl. - What lube to use? (EnjoyTheRideDC2)
Someone knows...
Old Aug 11, 2006 | 12:40 PM
all-mtr-teg's Avatar
What's urea grease, isn't urea a chemical in ****?
Old Aug 11, 2006 | 01:57 PM
Zulu888's Avatar
Default Re: Clutch Slave Cyl. - What lube to use? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">What's urea grease, isn't urea a chemical in ****?</TD></TR></TABLE>
give it a shot, won't cost you anything
Old Aug 11, 2006 | 02:17 PM
Default Re: Clutch Slave Cyl. - What lube to use? (Zulu888)
^^^ haaha. All I know is Honda has a lube called High Temp Urea Grease...
Old Aug 11, 2006 | 03:59 PM
-Kirk-'s Avatar
I've always used assembly lube and never had any problems.
Old Aug 11, 2006 | 10:48 PM
Default Re: Clutch Slave Cyl. - What lube to use? (-Kirk-)
I used bearing grease on mines about 9 months ago, still looks good today, 10k miles later
Old Aug 12, 2006 | 08:01 AM
gsr dood's Avatar
lithium grease, that **** never breaks down. its used for throwout bearings.
Stoich
11
Nov 6, 2007 04:30 PM
crxmex
Mar 12, 2007 06:30 PM
chomorro
Dec 21, 2006 09:56 AM
NONKonformyst
Oct 21, 2002 07:07 PM
nugget8000
Aug 21, 2001 07:22 PM
