Suspension & Brakes Theory, alignment, spring rates....
steep driveway and big sway bars..
Old Aug 11, 2006 | 02:00 AM
do_0b's Avatar
Default steep driveway and big sway bars..
Ok guys heres my situation. I just moved to a house with a pretty steep driveway and the only way to get up and down it without scraping badly is sideways, one wheel at a time. I have heard doing that is bad for the subframe on cars with bigger sway bars. I drive a em1 with 22mm sway bar and the ASR brace. My question is would the ASR brace be strong enough to withstand all that stress of going up and down the driveway? Should i take it off or leave it? i really dont want to park my car outside, please help!
Old Aug 11, 2006 | 08:38 AM
Tyson's Avatar
Default Re: steep driveway and big sway bars.. (do_0b)
i dont see how going up your driveway slowly is any worse than normal street driving.
Old Aug 11, 2006 | 10:53 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: steep driveway and big sway bars.. (Tyson)
This is the very reason why you purchased the ASR reinforcment kit in the first place. I have not heard of single failure with this kit yet, and only 1 or two failures with the comptech kit. Just make some quick sub-frame inspections every time you do an oil-change & call it a day...
Old Aug 12, 2006 | 06:23 PM
suspendedHatch's Avatar
Default Re: steep driveway and big sway bars.. (94eg!)
Well, going up the curb into the driveway you can end up on three wheels. To do that in racing, you have to take a hard turn with a thick rear sway and a weak front sway or some other misguided setup.
I should take a pic of my car on three wheels parked in my grammas driveway. It's freaky *** ****.
thick swaybar = not a truely independent suspension
Old Aug 14, 2006 | 11:22 AM
SilverDc2's Avatar
Default Re: steep driveway and big sway bars.. (suspendedHatch)
i had a comptech for 3-4 years on steep driveways 3wheeling everytime without a problem.
Old Aug 16, 2006 | 11:15 PM
mortarion's Avatar
you should be fine man, my CTR ***** a leg everytime i go into a driveway.
and the hella angles are the way to go!
Old Aug 17, 2006 | 06:18 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">This is the very reason why you purchased the ASR reinforcment kit in the first place.</TD></TR></TABLE>
To prevent subframe damage/tearout.
Killtodie
Honda Civic (2001 - 2005)
42
Sep 30, 2006 12:46 PM
mrdeadman
Aug 1, 2005 02:47 PM
NTGR8D
Nov 30, 2003 11:50 AM
B00stedCoupe
19
Nov 12, 2003 08:56 AM
crazy_ham
Apr 6, 2003 08:59 AM
