BKR6ES-11 or BKR6EGP ?????
Old Aug 10, 2006 | 09:31 PM
1990hondaHF's Avatar
Default BKR6ES-11 or BKR6EGP ?????
BKR6ES-11..$1.77 standard plug (says: "All NGK Spark Plugs are OEM Approved")
BKR6EGP.....$2.99 G-Power Platinum Plug
This is for a STOCK GSR...I/H/E....normal bolt-on's
http://www.partsamerica.com/Pr...set=A
info from there.
WHICH ONE???????????
Old Aug 11, 2006 | 01:09 AM
Dartanian's Avatar
Default Re: BKR6ES-11 or BKR6EGP ????? (1990hondaHF)
Either or.
The platinum plug will last longer. The copper plugs will have to be changed every other oil change, but the platinum plugs will maintain OEM replacement intervals.
Old Aug 11, 2006 | 02:38 AM
EnjoyTheRideDC2's Avatar
Default Re: BKR6ES-11 or BKR6EGP ????? (Sleeper Style)
Up to you. I dont know for sure if that platinum plug is exactly as tough as the OEM preferred replacement part number. The standard copper plug will need to be changed just about every second or third oil change. I change mine every 3rd oil change unless I notice some signs of ingition related issues.
I like the copper plug just because when I change them, I can inspect the plug for anything that might tell me info about my motor and how its running.
But as far as performance of the plug, they will both do the job similarily, just the platinum plug may last longer than the copper.
Old Aug 11, 2006 | 09:34 AM
Default Re: BKR6ES-11 or BKR6EGP ????? (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I like the copper plug just because when I change them, I can inspect the plug for anything that might tell me info about my motor and how its running.</TD></TR></TABLE>
good point!
Old Aug 11, 2006 | 10:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I run BKR6E-11's and change them every 10K-15K miles. They've been working great for me for well over 100K miles.
slammedda9
Jul 5, 2008 01:55 PM
CR91X
May 24, 2008 04:13 PM
mongoliandonuts
Aug 27, 2004 11:51 PM
gixxer6
Oct 29, 2002 01:10 PM
