Need your help.....
Old Apr 24, 2002 | 08:07 PM
CRVtecRex's Avatar
Default Need your help.....
I did a search but found no results.
I have a 91 crx si...I'm planning on adding a turbo kit. Will a 92-95 civic sohc greddy turbo kit fit on my car? and...what modifications need to be done in order for it to fit.
Thanks in advance,
Chris
Old Apr 24, 2002 | 08:18 PM
EP3_05's Avatar
Default Re: Need your help..... (PoweredbySPAM)
It will fit. The exhaust manifold will need to be modified. You will have to move your battery to accomodate the charge pipes unless you custom make your own. You will most likely need to ditch AC if you have it. The front crossmember needs to be modified to clear the downpipe. You will need to get some sort of fuel setup since the greddy blue box and injectors will not work with your stock motor and ecu. The oil pan will need to be tapped and a flange welded to it for the oil return line. That is really all that needs modification or you could buy the drag gen2 kit for the 88-91 civic/crx which is pre-mae for your motor.
Old Apr 24, 2002 | 08:19 PM
RexB16's Avatar
Default Re: Need your help..... (91civic)
damn tiny *** ef engine bays. my motor looks like a big block stuffed into a cavalier in there.
Old Apr 24, 2002 | 08:28 PM
No More Civic's Avatar
Default Re: Need your help..... (RexB16)
You could just get a Jackson Supercharger since they make one for the Si, but I wouldn't advise it. Because 1) superchargers suck, and 2) it costs like $2500. So, not only are turbos better for your car ie. don't put as much wear on it as a belt driven parasite, but they cost less and have more potential.
Old Apr 24, 2002 | 08:38 PM
handiman15's Avatar
Default Re: Need your help..... (SlowCivicDX)
why not just get an f-max kit, fmax makes awesome kits. also, if you want dependability and less maintenance go w/ the superchgr
Old Apr 24, 2002 | 08:39 PM
CRVtecRex's Avatar
Whew! That is a lot of crap to go through for boost! Thanks for the post. I kinda had a feeling about the crossmember and ac...
I'll have to look into the drag kit.
Old Apr 24, 2002 | 08:58 PM
rioninja's Avatar
1) please provide some reasons why "superchargers suck"
2) are you retarded? (no offence to retarded people). Turbochargers provide -MORE- wear on the motor. The oil is heated and broken down faster, and in the case of water cooled turbos they put a little more stress on the cooling system combined with the added stress that forced induction cars already have on the cooling sys.
Please dont give out misinformation. Of if thats just your opinion, please state it as such. and poweredbyspam, sorry for getting off topic.
sc34dc4
Welding / Fabrication
Feb 3, 2011 08:44 PM
DualCamDan
Sep 9, 2004 07:06 PM
quicksol95
Mar 7, 2004 08:02 PM
snt78
Mar 7, 2002 02:34 PM
