Will a Greddy turbo manifold fit my 98 sohc civic from a 92-95 kit?
Also i know my car has obdII so the computer from the the 92-95 kit will not work
so can i use a v-afc with 450cc DSM injectors
or should i use
FPR with like a 10:1 disc or 12:1 disc with my stock injectors
and also what egt temps should i be safe to run?
thanks
or should i use
thanks
Re: Will a Greddy turbo manifold fit my 98 sohc civic from a 92-95 kit? (slowsohccivic)
Yes, I have a whole 92-95 kit on my 97 hatch. I am running the E-Manage that came with the kit on my OBDII motor. And if you had to choose between those two, I'd pick the AFC hack. It's tunable whereas the other is not.
the greddy manifold will work. If you are talking about the blue box yes that will work also. the 92-95 greddy kit will fit 96-00.... go to turbocivic.net for info...better yet do a search! you will find more info that you will want to know.
Re: Will a Greddy turbo manifold fit my 98 sohc civic from a 92-95 kit? (CTL)
the kit has the blue box not the e-manage the kit also comes with no injectors is that correct and what kind of boost can i run on a stock sohc v-tec motor? with that turbo.
IhateMy93BlackHatch
12-07-2003 10:21 PM
KC GSR
06-17-2002 10:21 AM
