Cluster Problem
My cluster is not working right. The backlight only lights up and the battery icon. Nothing else on the cluster move, rpm, speedo, temp.
GSR in a 92 Si
IntegrA dash
GSR in a 92 Si
IntegrA dash
check your grounds, all of them. should be one from the valve cover to driver sides radiator support. one from tranny to passener side frame rail. and one on the thermostat housing. also check the one in the fuse box on the passenger side shock tower.
check all fuses too.
yeegsr
Jun 28, 2005 10:40 PM
