Please Help! 90 EX squealing noise
Old Aug 10, 2006 | 08:32 PM
dajoyner's Avatar
Default Please Help! 90 EX squealing noise
I am at my wits end with this problem. Couple of weeks ago it started to make a slight squeak every once in a while. So I got the belts changed. Didn't help, in fact it got worse. Took it back to the shop and they said it is most likely a bad bearing on the compressor. At this point it was sqealing bad at start up, when I came to a stop, and when I started driving, with the A/C on. But it would pretty much go away once I was up to driving speed.
So I bought a used compressor and had the shop install it. Of course they had to retrofit to R134. Well after $195 worth of work it is slowly starting to make the exact same noise in the same conditions, (a/c on). Please help me and let me know what it could possibly be. I really need to figure this out. Thanks in advance.
David
Old Aug 10, 2006 | 08:46 PM
1990AccordEX's Avatar
Default Re: Please Help! 90 EX squealing noise (dajoyner)
sounds like the Alternator/Ac belt isn't tight enough, under the alternator there two bolts 10mm tight the one on the right toward the belt till the squealing noise stops
Old Aug 10, 2006 | 08:48 PM
dajoyner's Avatar
Default Re: Please Help! 90 EX squealing noise (1990AccordEX)
Thanks. I will try that in the morning.
crxtreme27
May 11, 2005 09:05 PM
RCautoworks
Jan 16, 2004 12:26 PM
Zuerst
Jan 13, 2004 11:33 AM
preludebabygrl
Apr 6, 2003 09:43 AM
