anyone kno code 8 on a b16 ecu
i have a d16z6 in an ef hatch with a b16 ecu n the light blinks 8 times...which i guess is code 8... im tryin to figure out what the code means n what i have to do to fix it.... thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La EF-8 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1710584
Thought that i would help you out since im not an ***</TD></TR></TABLE>
lol. There are also FAQs on the top of the page in the CRX/EF Civic forums. Theres tons of information and a good time to learn new tricks.
you probably have more then 1 code also..seeing how you're running the b16 ecu on a d16z6.....Unless you added a knock sensor to the engine and hooked up a 2nd o2
honda06si
Feb 12, 2005 02:54 PM
