Max Piston to wall clearance?
Old Aug 10, 2006 | 04:36 PM
black99x's Avatar
Default Max Piston to wall clearance?
Has anyone ever had a piston to wall clearance of over .05mm? If so what is the max you have seen? With .06 or .07mm would there be piston slap?
Old Aug 10, 2006 | 06:46 PM
Natural Aspirations's Avatar
I guess it would depend on your piston, Wiseco recommends .0635mm or .0025"
.05mm is less than .002"
Old Aug 10, 2006 | 07:04 PM
black99x's Avatar
Default Re: (EJDan)
I'm using JDM ITR Pistons
Old Aug 10, 2006 | 10:20 PM
b19coupe's Avatar
Default Re: Max Piston to wall clearance? (black99x)
Factory specs are .010-.040mm (.0004-.0016")
Factory service limit is 0.050mm (0.002")
If I was using factory pistons I would not go looser than 0.0015", and I would shoot for 0.0010".
Old Aug 11, 2006 | 04:14 AM
black99x's Avatar
Default Re: Max Piston to wall clearance? (b19coupe)
So your saying the bore can be up to 81.0254mm? The piston bore is actually 80.97mm so that is already .03mm- Are your numbers taking that into consideration? If you are and your saying you would not go any looser then .0015" or .0381mm then you are leaving .0081 for piston to wall clearance?
Modified by black99x at 7:04 AM 8/11/2006
Old Aug 11, 2006 | 06:35 AM
b19coupe's Avatar
Old Aug 11, 2006 | 07:40 AM
black99x's Avatar
Thank you- That explains it perfect. I hope that it is within spec!
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
JDM97R
Jan 13, 2013 08:22 AM
amadriga
Nov 13, 2007 11:11 AM
litovi3tboi503
May 11, 2007 09:12 AM
supergreenNA1
Mar 24, 2002 02:19 AM
