Tube not connected
Old Aug 10, 2006 | 03:48 PM
AZNracerx1989's Avatar
Default Tube not connected
I found a tube that is not connected to anything in the top right of the engine bay. There is a container and this pipe comes out of it... I will take pics later.
It is a b18c1 engine. What does the tube connect to?
Old Aug 10, 2006 | 04:00 PM
HXvtec's Avatar
Default Re: Tube not connected (AZNracerx1989)
pics?
Old Aug 10, 2006 | 04:07 PM
my camera is outta battery... lemme recharge a little really quick lol
Old Aug 10, 2006 | 05:43 PM
That is what is disconnected..
And, what is this?
Old Aug 10, 2006 | 06:04 PM
Archidictus's Avatar
Unceasing Measure
The second pic is a vacuum diaphragm on your throttle butterfly. The first pic is a tube that's supposed to be connected to an air-intake vacuum source.
Old Aug 10, 2006 | 06:12 PM
SmogKing's Avatar
That's the EVAP purge, the loose vacuum line goes on your throttle body.
Old Aug 10, 2006 | 06:13 PM
what is it supposed to do? without connecting it, what are the consequences? thank you
Old Aug 10, 2006 | 07:44 PM
built562's Avatar
emissions hose #7 goes from the charcol canister to the evap purge solenoid thats located on the intake manifold. the car will run perfectly fine with out it but you will not pass smog if they see it hanging.
b18c1? the sensor should be there, jdm motors dont even have these sensors so the hose will need to be capped
accord99power
May 28, 2008 01:55 PM
HaNsElBaDaSs
Nov 5, 2006 08:58 AM
EF8IGHT
Nov 8, 2005 07:53 AM
McNizzle
13
Nov 15, 2004 11:06 AM
Gunns
Aug 15, 2003 09:35 AM
