Where do the EVAP hoses go?
I have one vaccum hose that is just dangling from the main evap cannister by the battery and i dont know what it plugs into. does anyone have any pics? I have a skunk2 IM if that makes any difference. Thanks!
Re: Where do the EVAP hoses go? (Chris M)
sorry no pic but since you have that skunk man it does not have a port for it. you should of drilled and tapped one for it if you want to use it. the car will run ok without it.
you dont just leave it hanging there .... spend $3 and buy a " T " and tap the vaccum line from the pcv valve to the manifold.......otherwise you are just allowing your evap system to release fuel vapors in your engine bay (it kinda hot in there) can you say boom boom
Re: Where do the EVAP hoses go? (bleedblue94)
how much vapor is actually dispersed out of the hose?? I mean it would take a considerable amount of vapor to ignite...like practically spraying gas into the air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">but why would you even do it when all you have to do is buy a t and tap the pcv hose</TD></TR></TABLE>
true i think ill go with the T. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M »</TD></TR><TR><TD CLASS="quote">true i think ill go with the T. thanks </TD></TR></TABLE>
no prob
no prob
