Do I need to reinforce if upsizing rear sway from 13mm to 14mm?
As the topic says...if I replace the 13mm rear sway on my 98 RS coupe with the GSR/LS sedan 14mm bar is there any need for reinforcement?
Does the sedan have any extra support?
Thanks
Thanks
Nevermind.
I'm going to go 19mm and use some type of reinforcement.
Are there any 19mm rear sway bars that do not require drilling new or larger holes for installation? I think that both the Beaks & BSQ kits requires drilling.
I have also decided against using the Comptech or ASR rear brace at this point in time because they both attract unwanted attention to my car. I'm trying to keep this car a sleeper and a flashy aluminum bar isn't easy to hide.
And for the type of driving I do both these bars are overkill IMO.
I also think the 22mm bar is a little large for my car unless I increase the front sway bar to 24mm(like the GSR), again this is my opinion and related to my car only.
Modified by JohnQPublic at 5:47 PM 8/10/2006
Modified by JohnQPublic at 5:50 AM 8/11/2006
ekinshuya
May 31, 2009 07:36 AM
EJ1 wilcox
Suspension & Brakes
23
Mar 14, 2006 12:49 PM
