Feels like a dog
Goin on 96,000 Miles w/ stock clutch! As soon as I run this into the ground I'll have saved up enough for a swap.
But in the meantime... could use some pro honda suggestions...
I bought the car with 36,000 miles.. it's an EX 2.2 SOHC VTEC 5-spd. When I bought it, it felt GREAT! ALOT stronger than it feels now
I could race my friends V6 4-door Accord and beat him in the quarter by a carlength.
The only things I've done to the engine are a removed resonator and drop-in K&N filter, Greddy exhaust, and advanced timing (17degrees)
I did the big 90,000 tune up from honda a little early. So... everything should have been checked and replaced according to the service schedule.. meaning.... timing belt, pumps, hoses, cap, rotor, filters, etc etc.
The problems I'm having are as follows.
Slow as a dog and feels like a stock civic. With the A/C on it's even worse
It idles at like 650 steady.. but when I blip the throttle and the rpms go back down the idle drops under 500 for a split second then back up to 650.
Also, when I turn my steering wheel when NOT in motion, I notice my idle drop like 150 rpms then go back up...
Besides all the work honda did, I change my oil religiously w/ MOBIL-1 5W-30 Synthetic and keep up with my maintenance pretty well.
I could race my friends V6 4-door Accord and beat him in the quarter by a carlength.The only things I've done to the engine are a removed resonator and drop-in K&N filter, Greddy exhaust, and advanced timing (17degrees)
It feels sluggish because the temperature has been getting warmer, thus your engine is not as cool and responsive.
The engine is just old. Scratches made in the cylinder walls over time have reduced the compression ratio, and the advanced timing may have impacted your piston rings whether you know it or not.
What can I do to get it back up to par that won't cost me an arm and a leg ?
suggestions guys.... i know there's some smart honda techs out there...
I'd like to know why it's driving like crap all of a sudden.
Read the 1st post.. it describes in detail what's going on.
i've never set timing before so I don't know the exact procedure, however I have the basic idea. Maybe it's just my timing... maybe a vacuum hose... i dunno, what should I check ?? Man.. for a tech board I'm not getting much help.
Does advancing the timing have negative effects in the long run??? What if higher octane is always used after advancing?
what is the maximum amount the accord can advance? is it 20degrees? Is it worth it to advance it all the way? I recall seeing a discussion here about losing power if you advance it too much. I was thinking of 17-18degrees on 91-92 octane (best in my area).
I know a certain Prelude VTEC driver who eventually cracked some valves on his H22A1 due to advancing ignition too high. I think he was right around 18 degrees. Do a compression test.
jmk64
19
Oct 19, 2010 05:05 AM
joychri
Mar 19, 2008 07:29 AM
94HondaAccord_LX
Jan 3, 2008 03:46 PM
