Low compression Across the board
Old Aug 10, 2006 | 02:31 PM
Topdawgg's Avatar
Default Low compression Across the board
I bought a spare b18b from someone for dirt cheap... he said it had low compression right across the board... he said like 40 on each...
now, was he just checking it wrong, or is there somethin i can do .... Rings maybe?
i know what low compression in one cylinder is, but not all 4 evenly
Old Aug 10, 2006 | 02:49 PM
QuickDxEk's Avatar
Make sure the engine is at operating temp. Also check the valve clearances. When I first got my b16 i tested it cold, like hasnt ran in weeks and it was like 50. When i ran warm it was 210 across the board!!
Old Aug 10, 2006 | 03:20 PM
Topdawgg's Avatar
well i never heard this motor runnin, and its ripped apart now.... but if it could just be that it was cold, then all it needs is a hone..
Old Aug 10, 2006 | 03:37 PM
QuickDxEk's Avatar
Well, If it is apart than you check everything out. Look at the cylinders, look for scrapes or marks and on the pistons!
kornerk12
Jan 5, 2006 07:20 PM
Pandahatch
19
Jul 11, 2005 11:05 PM
boostedinteg03
Apr 11, 2003 12:47 PM
311
Dec 14, 2002 12:18 PM
stupidfast
Oct 20, 2002 03:50 PM
