HELP hooking up intake manifold
Old Aug 10, 2006 | 02:11 PM
agy2k2's Avatar
Default HELP hooking up intake manifold
I put this GSR motor in my EG and need help hooking up the lines.
Any idea where this line goes? comes off the canister. and is the line i highlighted red hooked up correctly?
where does this line go? comes right off the bottom of the throttle body
where does this coolant line hook up to? i was thinking it needs to be twisted the other way and hooked the the solid line behind the block...
where do i hook these vacuum lines to? i only see the one nipple on the back on the intake manifold.
i would really appreciate any help with this. this is my first swap. thanks!
Old Aug 10, 2006 | 02:13 PM
Lan's Avatar
Lan
Default Re: HELP hooking up intake manifold (agy2k2)
The coolant line hooks up to the plug where the thermostat is. The FPR has a line that hooks up to the IM, without that line it will idle high.
Old Aug 10, 2006 | 02:28 PM
zeroz's Avatar
Default Re: HELP hooking up intake manifold (Lan)
the fpr and actuator for the butterflies T together and go into the small nipple there along with the black canister on bottom of the intake mani ...i think.... i just put in a new S2 IM and when i took the stock one out all those were T'd together in some weird way
Old Aug 10, 2006 | 02:31 PM
zeroz's Avatar
Default Re: HELP hooking up intake manifold (zeroz)
Old Aug 10, 2006 | 05:38 PM
agy2k2's Avatar
the diagram helped a bit, but i think mine is different because its obd2. anyone else have any input?
Old Aug 11, 2006 | 04:00 AM
agy2k2's Avatar
anyone else?
Old Aug 11, 2006 | 05:30 AM
hybridej7's Avatar
Default Re: (agy2k2)
think what zeroz and Lan said are correct.... you could skip all that mess and get a skunk2 manifold.......
95CoupeDX
Feb 5, 2008 06:54 AM
SlipGear
Jan 19, 2008 02:33 PM
agy2k2
19
Aug 14, 2006 05:19 AM
EM1specR
Mar 15, 2005 01:17 PM
