My set up 92 civic cx
This is my set up. What else can i do to it. It is my daily driver and i just want to hit the drag strip on weekends.. How much power should i be expecting.. I still need another 1000 miles to break in my car.. After break in i will dyno tune it..
1992 Honda Civic CX
B18A Bottom End
B18C5 Head
PR3 Pistons
Crower Rods
ARP Headstuds
ARP Rod Bolts
81.75MM Bore
Line Bore
Knife Edged Crank
Port and Polished head
3 Angle Valve Job
GSR Cams
Ferrea Springs
Ferrea Retainers
Skunk2 Pro Race Intake Manifold
Mugen Headers
Apexi WorldSport Exhaust
Custom Mandrel Bent 2.5” Exhaust Piping
Injen Short Ram Intake
Act Heavy Duty Pressure Plate
Act Street Disc
Act Light Weight Flywheel
AEM Fuel Rail
B&M Fuel Press. Reg
B&M Fuel Press Gauge
P28
Hondata s200
Walbro 255lph Fuel Pump
Modified by vbherrera at 6:05 AM 8/19/2006
1992 Honda Civic CX
B18A Bottom End
B18C5 Head
PR3 Pistons
Crower Rods
ARP Headstuds
ARP Rod Bolts
81.75MM Bore
Line Bore
Knife Edged Crank
3 Angle Valve Job
GSR Cams
Ferrea Springs
Ferrea Retainers
Mugen Headers
Act Street Disc
AEM Fuel Rail
B&M Fuel Press. Reg
P28
Hondata s200
nice setup!
....i assume its chipped?... i estimate 190-205whp...you have the springs and retainers, you should of saved up a lil more and put in cams as well..that alone would put more ponies on the dyno.
yes dirty engine bay.. that was a pic while it was still being finished.. i do need to clean it though.. i got the type r head with th vavletrain in it.. and the gsr cams.. i will go with skunk 2 stage 2.. but i want to dyno it first and see what it does before the cams..
The car also has skunk2 full race coil overs, and the complete energy suspension bushing kit. For brakes i have gsr disks all the way around with stainless steel brake lines and an upgraded master and slave..
nice...any more plans with the motor n/a or boost?...save a lil more if you go all motor, and ditch the IM, get bigger injectors, ITB's and tune, and you'll be owning
yeah im going to stay n/a.. i love the reliability and the constant power.. My wife has a 93 cx and we are currently building a dart block for her.. she wants boost.. she rides with a 6 puck act unsprung clutch.. she is nuts..lol
keep it in mind, i have a friend who had a fully built LS/VTEC in his EG6 hatch, rhd, on stage 3 cams, ITB's and running 101 oct...being in the back seat my feet never touched the ground.
vbherrera
22
Jul 7, 2006 12:07 PM
