CD Deck Cutting Out But Still Has Power. Searched To No Avail.
Old Aug 10, 2006 | 10:56 AM
crxforum's Avatar
Default CD Deck Cutting Out But Still Has Power. Searched To No Avail.
I have an Alpine double din deck. No idea the model. Its from Japan and plays CD and MDs. I dont have MDs so have no idea if that even works or not. Anyways long story short songs will just cut out and then come back on or it will say "Compact Disc Error" then I have to hit play again and sometimes it will come back. Other times I have to eject the CD and put it back in and it will work.
Ive noticed that sometimes the CD is warm when I take it out and when I downshift it tends to cut out a lot more. There is still power to the deck at all times. The music just stops. Anyone have any idea what this might be?
Thanks
CRX Forum
Old Aug 10, 2006 | 11:03 AM
B18C_EJ8's Avatar
Is it overheating???
If it "resets" itself after you eject the CD, sounds like a potential microprocessor issue, like it's locking up...
Have you tried resetting the deck? Is there a reset button? Try pulling all power from the deck for a few minutes, and starting over...
All I can think of right now...
Old Aug 10, 2006 | 11:49 AM
crxforum's Avatar
Default Re: (B18C_EJ8)
I have no idea if it is overheating. I just got the deck and have only used it for like 3 months and it has been doing it since the first week I got it. It seems though as time goes on it gets considerably worse and have no idea the problem. The CD is not amazingly hot just warm.
No it doenst reset it self. The CD player stays on at all times unless I turn it off manually.
CRX Forum
Old Aug 10, 2006 | 01:44 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Is it overheating???
All I can think of right now... </TD></TR></TABLE>
i have an alpine right now, and mine plays cd's but the screen and all the buttons freeze up on me. called tech support and they said it's the microprocessor starting to go out. this deck is semi-brand new out of the box but old design. it might be something that alpine has to deal with and fix.
i also get the whole "disc error" when i turn the car on and everythign starts up. i could of turned my car off 5 min.s prior, turn it back on and get that error, when everything was working fine 5 mins before.. idk, it's weird but my new Pioneer AVIC-D2 will replace it soon and i can sell this to someone else
Old Aug 10, 2006 | 01:52 PM
crxforum's Avatar
Default Re: (..::91TEG-G2::..)
I dont think that its an over heating problem though because it will happen right away when I turn on the car. Like I left from work and it didnt even play, just went right to error. Could it be that the lens is messed up, not alligned correctly, or just dusty?
CRX Forum
Old Aug 10, 2006 | 02:07 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (crxforum)
best bet is to send it to alpine to figure out why because it seams internal
Old Aug 10, 2006 | 03:39 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Could it be that the lens is messed up, not alligned correctly, or just dusty?CRX Forum</TD></TR></TABLE> Yes it can, have you tried a lens cleaner?
Old Aug 10, 2006 | 09:27 PM
Default Re: (fcm)
lense cleaners wont work i dont think, if i read it correctly. hear me out.. it's the processor going out. if you read my post above, you'll know eactly whats wrong with yours, which is exacly what's wrong with mine. dont believe me? contact crutchfield, or contact alpine directly
Old Aug 11, 2006 | 08:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">lense cleaners wont work i dont think, if i read it correctly. hear me out.. it's the processor going out. if you read my post above, you'll know eactly whats wrong with yours, which is exacly what's wrong with mine. dont believe me? contact crutchfield, or contact alpine directly</TD></TR></TABLE> It may not, and yes the processor may be the problem, but I have been an installer for over 30 years and an Alpine installer for about as long as Alpine has been around, and I can't count the number of times I have "fixed" CD cutting out problems by just running a lens cleaner, [high quality lens cleaner] in the HU, it is a cheap easy fix if it works, if not you have lost nothing, if it does work problem is solved and you have saved having to pull the HU and the cost of sending/taking it someplace to have them run a lens cleaner through it, [it is the first thing a repair shop will do]. 94
Old Aug 11, 2006 | 09:24 AM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> It may not, and yes the processor may be the problem, but I have been an installer for over 30 years and an Alpine installer for about as long as Alpine has been around, and I can't count the number of times I have "fixed" CD cutting out problems by just running a lens cleaner, [high quality lens cleaner] in the HU, it is a cheap easy fix if it works, if not you have lost nothing, if it does work problem is solved and you have saved having to pull the HU and the cost of sending/taking it someplace to have them run a lens cleaner through it, [it is the first thing a repair shop will do]. 94</TD></TR></TABLE>
very true, i mean i made my past statement with the support of bad info. i read somewhere that having a lense cleaner in a deck is not recomended.. like there are some things it can be ran in, and others it can't and would mess the device up. maybe i'm getting it confused with my old Xbox system before i tried to fix it and ended up taking it back
well i will try the lense cleaner, it's just the simple one with the little Ned Flanders pushbroom brushes on it right?
Old Aug 11, 2006 | 03:04 PM
fcm's Avatar
fcm
Old Fart
well i will try the lense cleaner, it's just the simple one with the little Ned Flanders pushbroom brushes on it right?</TD></TR></TABLE> No, you are correct, cheap *** CD cleaners can knock the lens out of alignment, and of coarse no lens cleaner will help if it's already out of alignment or something is stuck to it real good, but I have been using a very good one for years, [I think the brush hairs are made from the the pubic hairs of a female silk worm, or something like that, very soft and flexible] I have used it and still do on anything that uses a disk, including a Play Station 1 and 2 my computer and any number of car CD players, [oem and aftermarket] but not on an Xcix yet.
And as I said, it's just something to try first, before you spend money getting the unit fixed, because even if that is all that is wrong, [crap on lens] a repair shop will do a full cleaning and lens alignment and charge $75 - $100 or more. 94
Old Aug 11, 2006 | 07:37 PM
Default Re: (fcm)
alright, well do you think you can post some brand(s) info on good cd cleaners, and maybe some pictures of either yours or the manufacture photo's so i/we can see what a good cd cleaner looks like?
Old Aug 12, 2006 | 10:27 AM
fcm's Avatar
fcm
Old Fart
Mine is a TDK pro, there are more then a few... http://www.google.com/search?s...aners generally the price of the CD will tell you which one is a good one. 94
Kinderhauler
Audio / Security / Video
Dec 3, 2007 12:14 PM
gobblebox59
Nov 7, 2004 06:49 PM
SpoolinEK9
Mar 5, 2004 09:54 PM
asiandoood
Oct 28, 2002 11:34 PM
