Air fuel mixture with Autometer gauge
How many of you guys are using them? Do you get a range of about 4 to 5 lights being lit as the display goes from left to right? If you are then something is not right and we need to work together to fix this. It's a common problem with hondas and I see other hondas here with the same problem and I'm convinced it affects performance. The computer is basically seeing this (blurr) change in readings and trying to compensate accordingly. I already change my O2 sensor same problem. I also change my guage thinking it was bad. Is this happening to any of you guys? When I first installed the guage it lit up one led at a time and the car ran perfect
Now even at full throttle I get about 4-5 leds on in the rich area. We really need to solve this.
I'd guess you have a ground or noise problem.
the O2 oscillates at cruising from ~.3-.75 volts. This can be quick enough to be a blur.
But if you're getting a blur at WOT you have a problem.
either electrical or tuning.
