D16A6 flywheel questions
Old Aug 10, 2006 | 08:42 AM
( o )( o )'s Avatar
Default D16A6 flywheel questions
I just removed the tranny/clutch/flywheel in my 90 civic Si.
The clutch was bare metal and has dug rings into the pressure plate.
The flywheel surface looks smooth, and I didn't see any light under the straight edge. I didn't see the part in the Helms about putting a dial indicator on the flywheel while its still on the motor until after I removed it.
I also did not see any specific instructions to have it machined.
Furthermore, it is different than my B Series flywheel - the clutch mating surface is sunken on the D series and raised on the B series. Is it supposed to be sunken, or did my bare clutch grind it down too far? not sure if i need another flywheel or not...how deep (if at all) is the d series flywheel mating surface supposed to be. I'll try to take pics afterwork....
slowesteg
Aug 20, 2016 03:26 AM
EG1.8cT68
K Series
Dec 3, 2015 07:58 AM
Mr.Callofduty2
Jul 13, 2010 05:11 AM
94_teg
Feb 25, 2009 04:22 PM
